HID questions..
Old Aug 23, 2017 | 09:36 PM
RayneLeaf's Avatar
HID questions..
So I bought my car with HIDs and one of them is burnt out. and the other is dimming. Can I just buy bulbs or do I need to buy an entire kit? Doesn't matter if I have to buy a new kit, I'd probably go with brighter ones anyways. Just wondering
Old Aug 23, 2017 | 11:00 PM
keiserX13's Avatar
Depends if its the bulb or the ballast that is causing the issue
best way to check is to swap the bulbs side to side and see which the issue stays with
Old Aug 24, 2017 | 02:02 AM
cluelessk's Avatar
Oh geeze.
Yes we can diagnose your car over the internet with almost no other info besides a HID problem.
If you want a fix that takes zero effort. Hire a mechanic.
They're probably just a cheap eBay kit. Just get a new kit.
Old Aug 24, 2017 | 04:06 PM
Anything related to the name Mike Ulrey run the other way
Old Aug 24, 2017 | 08:22 PM
BKRedline's Avatar
Oh geeze.
Seemed like a legit question and the first post answered him correctly. Why so butt hurt
Old Aug 24, 2017 | 11:40 PM
keiserX13's Avatar
that name still gets thrown around here?
Old Aug 25, 2017 | 03:41 PM
unfortunately
Old Aug 25, 2017 | 06:14 PM
RayneLeaf's Avatar
I swapped around my bulbs and it's for sure the blub. So I went ahead and ordered some new ones. Went with 8000k this time over 6000k
Old Aug 25, 2017 | 08:45 PM
Tdubbs's Avatar
8k isn't going to be brighter than the 6k, just so you know.
Old Aug 25, 2017 | 09:42 PM
keiserX13's Avatar
this
the higher the K the bluer the output
If you were looking for it to be brighter you should have gone with a 5000K or 4300K bulb
Old Aug 26, 2017 | 12:13 PM
BKRedline's Avatar
this
5 and 6k bulbs are the brightest. 4300 are more for fog lights and are generally illegal for headlights as are technically anything over 6k because of the color.
Old Aug 26, 2017 | 03:49 PM
Negative ghost rider. 4000-4300k is the range most OEM models use and the highest lumen output. 3000k are the yellow tint people like to use for foglights. 6k is about pure white slight color shift at the cutoff. Above 7000k they start turning blue
Old Aug 26, 2017 | 06:58 PM
RayneLeaf's Avatar
Amazon Amazon
I bought these thinking they would just fit but they don't and I don't know why. They work but simply wont fit into the stock assembly. Where can I find the right replacement?
Old Aug 26, 2017 | 09:21 PM
BKRedline's Avatar
That's right for some reason I brain farted and was thinking 4300 was yellow but ya the 3k are the yellows.
Old Aug 26, 2017 | 10:40 PM
keiserX13's Avatar
https://www.amazon.com/review/create...in=B00ZBBDW9Y#
those should fit the stock assemblies. what part wont fit?
Old Aug 26, 2017 | 10:45 PM
RayneLeaf's Avatar
The bit below the glass on the bulb itself. It's simply just too wide to find into the housing.
Old Aug 26, 2017 | 10:58 PM
keiserX13's Avatar
thats odd, they got shitty reviews on Amazon so id return them
