How the hell do you make NarrowBand Accurate??
i mean i hooked it up to the purple wire with the white stripe, and it basically dances around like all the time... considering there are like 4 or 3 of those purple wires in that loom i tried a bunch of diff one, as well as the one closeest to the o2 sensor, still same ****, no accuracy at all... i have an 07 , shud i connect the wire to a diff one, or whats the deal?
A narrow band is a 0-1v sensor who's range lambda is between .97 and 1.03. That's 14.3 to 15.1 in lamest terms.
A wide band is a 0-5v sensor where the lambda measurement is linear.
So what does this all mean? The reason the gauge is dancing is because the narrow band is not a linear sensor and is falling out of the accuracy range.
yea but it basically dances around all the time.. i know people on here have had accurate readings with a narrowband... i gotta prob just find another godamn wire again.... at wot, it sometimes goes to rich and stays if its lucky or sometimes it just reads more bullshit dancin way unaccurate...
OP- This whole situation will be solved when you sell that NB and get urself a WB. You'll never get an accurate reading on that LED lightshow.
