how to tap a fuse... properly?
Old Aug 7, 2008 | 09:12 PM
24SSNighthawk's Avatar
i have a 15 amp fuse tap and 10 amp fuses why cant i just plug and play with an empty existing fuse "spot" or am i missing something??
Old Aug 8, 2008 | 01:14 AM
EmperorJJ1's Avatar
empty fuse spot might not do what you want it to. but yes in theory you can do that
Old Aug 9, 2008 | 03:33 PM
whys that? and whats the "best" options
Old Aug 9, 2008 | 04:04 PM
Viper33884's Avatar
Go get a wiring diagram for your car and tap wires and put inline fuses.
Old Aug 9, 2008 | 09:09 PM
which would it be best to pull off of? what line?
Old Aug 9, 2008 | 10:03 PM
creedin's Avatar
its like sex, stick it in and pray to god nothing goes wrong
Old Aug 10, 2008 | 07:11 AM
ugh sex still scares me... thank god you cant make babies from cars... or am i about to?
Old Aug 10, 2008 | 07:55 AM
mkulrey13's Avatar
go to autozonem, get the mini fuse adders. Basicly you take a fuse you, plug this in there and then plug both uses to it and then connect the wire off of it to your wire.
Old Aug 10, 2008 | 12:32 PM
Viper33884's Avatar
Yea but you normally wanna run it from the IGN fuse which is I think 30 amps and the one's you can buy are only rated for 15-20 amps????
Old Aug 10, 2008 | 09:23 PM
correct, and so you have to run it from an existing fuse? and pull power that way? you cant create a whole new one? and get fresh unused power
Old Aug 10, 2008 | 09:32 PM
Stouffer's Avatar
I used a mini add a fuse in an empty fuse block for my gps, radar detector and wideband and haven't had a problem
Old Aug 10, 2008 | 09:42 PM
ugh why am i having problems
Old Aug 10, 2008 | 11:14 PM
EmperorJJ1's Avatar
not all fuses or slots have the 12v turn on your looking for. Not everything in the car is 12v and not everything is activated the same way as acc (some are constant some only turn on certain times ect)
You need to get a multi meter and test or use the ones we already know work
Old Aug 10, 2008 | 11:16 PM
Viper33884's Avatar
Best thing to do is go out and buy a build book for the car.
Old Aug 11, 2008 | 12:21 AM
EmperorJJ1's Avatar
either that or a multimeter... either way
Old Aug 11, 2008 | 12:32 AM
Viper33884's Avatar
Yea that too, and don't shove the test leads into the slots, you will spread the slots open and ruin the connectors.
Old Aug 11, 2008 | 12:39 AM
bridfi's Avatar
exactly. this is what i did for my dash neons. you can put 2 fuses for each, keep the fuse that was there, and then i threw on a 5A for the neons, theres 2 slots.
Old Aug 11, 2008 | 07:38 AM
alright i think i can do this, ill get the multimeter today and learn how to use that thanks sooo much for the help all, hope i can figure it out and learn something new def learn how to use a new tool
Old Aug 11, 2008 | 11:17 AM
Viper33884's Avatar
Yes please please read the directions, they have internal fuses but read voltage on Ohms you can still blow on up. And if you check the empty slots get a small piece of wire and stick in there to check it.
Old Aug 11, 2008 | 12:04 PM
EmperorJJ1's Avatar
u dont want to use ohms. Volts DC or VDC. ground one prong (try a non painted piece of metal, igntion key, or the easiest and most reliable.... outside of the cig plug) second prong needs to touch the metal part of the fuse or just slightly touch the metal if your testing one without a fuse. dont shove it in like viper said
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
Delta coupe
Sep 30, 2015 08:11 AM
goaliemo
Sep 28, 2015 01:37 PM
DocSvensk
Sep 27, 2015 02:24 PM
