Ignition to radio wire...
Old Dec 13, 2009 | 10:00 AM
CobaltLs_14's Avatar
Originally Posted by kingg5
are u talkin the accessorie wire?
its the wire so when the key turns over the radio turns on... any idea which one it is?
either tap a fuse or look for that wire. not sure if cs has pics but i dont
i tired the use and it just gave me problems and i tired to look for the wire but could not find it
Old Dec 13, 2009 | 02:50 PM
warrenb213's Avatar
some of the balt's don't have the sunroof circuit, pwr windows, etc actually active guys....
my car...has no RAP avail from the fuse box in any port.
Old Dec 13, 2009 | 10:58 PM
bump anyone know?
Old Dec 13, 2009 | 11:02 PM
silver187666's Avatar
what are you looking for now?
Old Dec 13, 2009 | 11:15 PM
hahaha same thing as b4 radio to ignition wire... with pic hopefully
Old Dec 13, 2009 | 11:25 PM
if its a aftermarket radio it should go to the wiring harness, its yellow it helps
Old Dec 13, 2009 | 11:42 PM
its for my gauges i have tired the fuse but all i get is issues so all fuse hook ups are out...
you have a pic? or can you take one and post it tomorrow or something....
Old Dec 14, 2009 | 12:16 AM
what gauge, i dont quite understand what your trying to do,
Old Dec 14, 2009 | 12:21 AM
kingg5's Avatar
this is not true.
i have a completely 150% base model ok. all u need is an add-a-circuit.
this thing
next you locate where the sunroof fuse SHOULD be.
stick into the spot where the sunroof fuse should have been.
THAT IS YOUR NEW RAP ACCESSORY WIRE!!
Old Dec 14, 2009 | 12:53 AM
nitrous, boost, and wideband
this is not true.
this thing
where can i get one and explain again how it works dont understand a little lost...
Old Dec 14, 2009 | 12:58 AM
  #36
so you just need somthing to turn them on and off when you leave the car?
Old Dec 14, 2009 | 12:59 AM
  #37
yeah basically...
Old Dec 14, 2009 | 01:02 AM
  #38
straight line from battery to trigger switch would be bad ass
you have aftermarket radio?
Last edited by silver187666; Dec 14, 2009 at 01:02 AM. Reason: Automerged Doublepost
Old Dec 14, 2009 | 01:07 AM
  #39
thats what i had in mind at first but i dont really want a switch i have to many already (nitrous on, bottle heater, sound system, nitrous shifter switch) all are hidden so you cant see them but still...
no i have a stock radio but plan on getting touch screen soon...
Old Dec 14, 2009 | 01:14 AM
  #40
hold out until you do, try to see if you can run the wire you want off the acc, it should work just like your radio does for up to 15 mins after the cars shut off
Old Dec 14, 2009 | 01:17 AM
  #41
the acc fuse (i dont like running it to a fuse because for some reason it never turns off i have already tried that)? or wire? which wire is it?
Old Dec 14, 2009 | 01:19 AM
  #42
its the yellow off a Aftermarket Hu, cause when you turn your car off it stays on for 15 mins, it may just work
Old Dec 14, 2009 | 01:23 AM
  #43
you have a pic?
Old Dec 14, 2009 | 01:25 AM
  #44
negative, contact glen229, he will be getting my old radio any day now, ask him to snap a picture of the ACC wire
Old Dec 14, 2009 | 01:26 AM
  #45
ok cool thanks i will
Old Dec 14, 2009 | 01:27 AM
  #46
good luck
Old Dec 14, 2009 | 01:29 AM
  #47
thanks i just sent him a pm
Old Dec 16, 2009 | 01:12 AM
  #48
brickloaf's Avatar
Omg not to the thread starter but this is the dumbest ******* thread i've ever read. Just take the remote wire coming out the back of your radio and run that bitch straight to your amp...the remote wire is blue or blue with a white stripe...mine was solid blue
Old Dec 16, 2009 | 01:14 AM
  #49
well brickloaf in stead of being a dick you could of simply said what the remote wire looked like. some of us are not familiar with gm wire colors
Old Dec 16, 2009 | 01:18 AM
  #50
brickloaf's Avatar
Tap it to the sunroof fuse and it will turn off when you take out the keys or open the door...you don't even need a add-a-fuse thing just shove a small wire (used as remote wire) into the sunroof fuse socket and stuff the fuse in to hold the wire in place
Not being a dick I just can't believe it took 3 pages to say the remote wire is blue and I know there are like 5 people that have already posted that definately knew this
