Interceptor question
Old Jul 14, 2011 | 12:46 PM
dmeine13's Avatar
I have an 07 ss/sc, what are the disadvantages of not taking out the jumper and just powering it from the OBDII port by plugging it in and out when you exit/enter the car?
Old Jul 14, 2011 | 12:47 PM
07BoostedG5's Avatar
why wouldnt you take it out?
Old Jul 14, 2011 | 12:48 PM
dmeine13's Avatar
why wouldn't i use the external power wire provided? not a fan of splicing whatsoever, just curious to see if there would be issues just doing this
Old Jul 14, 2011 | 12:51 PM
You have to splice? I was under the impression it will just power down once the car is off with the clip removed.
But to answer your question nothing, maybe wearing out the obII port with the constant unplugging/plugging but not likely
Old Jul 14, 2011 | 12:54 PM
dmeine13's Avatar
Thanks man! your help is much appreciated
Old Jul 14, 2011 | 12:58 PM
also if you use a add a circit no cutting is needed
Old Jul 14, 2011 | 01:01 PM
dmeine13's Avatar
do you have to get the wires to the fuse box?
Old Jul 14, 2011 | 01:05 PM
Acey's Avatar
Not sure if serious.
Disadvantages? You'll FORGET. Then it's goodbye battery.
Old Jul 14, 2011 | 01:56 PM
Just the panel on the passenger side, Find a acc item and plug in the add-a-circuit and your golden, I still need to do mine.
Old Jul 14, 2011 | 02:05 PM
dmeine13's Avatar
obviously
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
