Jensen VM9311
Jensen VM9311
Hey, I was looking at some labor day sales ads and saw that circuit city is offering a Jensen VM9311 In-Dash DVD/CD/AM/FM/XM/MP3 for $450 installed. I have been looking around and havnt found much as to how this unit is as if it is worth it or not. Only thing i could find is that it ties into the ebrake sensor and the display will not work when the car is moving unless you bypass this. So, I just wanted everyones opinions on this and see if anyone has this unit and if anyone knows how to bypass the ebrake issue if i decide to get this. Thanks
EDIT:
I found a wiring diagram and i zoomed in on the parking brake switch setup that they have for diabling the monitor if the brake is not on and to me this diagram looks like its saying there is a pink wire that all I have to do is ground out to bypass. Here it is below for everyone to take a look at
EDIT:
dude well I guess if your on a budget I run the sales floor at a cc in orange county make sure u get the warrenty cause those things always come back busted the motor ends up going out and the buttons end up falling off
Originally Posted by andy0405
go with the stores cause the manufactor's warrenty takes for ever to get back I've seen people with out there head unit for a month some times even more
No hard feelings, I'm just joking. I would get the extra warranty too.
Ok i have another question for everyone. I was looking at crutchfields website and i was looking into the installation of this deck. I found out that when you install an aftermarket radio you loose the information center. I dont know if that means the thing you hit to find song info or if that is the thing that tells you the oil life, water temp, etc. If someone can clear that up that would be great. They did say that there is an adapter that you can use to regain this feature, where would I get this at if I wish to keep the feature. FYI if its the song info i dont care but if its everything else then thats gonna suck and I want to be able to keep that
In short, since the information center on the cobalt is in the gauge cluster, you won't lose it by changing the radio.
