Kicker cv10
Old May 6, 2008 | 11:09 PM
Zdeuce4's Avatar
Kicker cv10
I bought a Kicker cv10 with a kicker ZX300.1 amp. Yes, I know it's small but my ears are sensitive to too much bass and since the sub can do 400 rms and the amp no more than 300 rms i figured it was a good setup for wut i like. Well i ordered it thru a friend and it finally came in but the sub was mounted in a small box to fit in a truck. My intentions are to find a stock cobalt pioneer box and swap my sub into it and get the box color matched and painted to my car (just my personal preference). My question is, the sub CAN be removed from the box and switched and still sound good right? Or are there some things that i should watch out for?
Old May 6, 2008 | 11:19 PM
EmperorJJ1's Avatar
yes. but the kicker will be too deep for the box
Old May 7, 2008 | 03:04 AM
Zdeuce4's Avatar
even though its shallow i can't get it cut or anything to fit?
edit** the kicker site says that its 4 3/16 of an inch thick or 10.7 cms. Do you know how deep the stock box is?
bump for answer on stock sub box depth
Old May 7, 2008 | 04:24 AM
InfinityzeN's Avatar
If I remember correctly, a touch less than 4".
Old May 7, 2008 | 09:52 AM
Zdeuce4's Avatar
so basically i would have to cut a a small portion off of the back of it?
Old May 7, 2008 | 09:40 PM
Yea. There are some people on the site that I know have cut holes in the back for the magnet of a sub and sealed around the edge. Don't know how well that worked though. Or you can make a lip ring that is just slightly thicker then you need (measure bro) to keep the magnet from touching the back of the box. Bolt it to the box, use some putty or bondo to smooth it into the rest of the box, and paint. You did say you were going to paint right? Think that way would work best if you are.
Old May 7, 2008 | 09:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
stock box with a kicker cv10 sounds like absolute crap
Old May 7, 2008 | 09:44 PM
Zdeuce4's Avatar
well here's wuts gonna happen... i got in touch with a guy who's gonna take the sub outta the box it came in and build me one to fit like the stock one. i have the option of getting a glassed one or carpeted, im probably just gonna do carpeted so that it will look stock. on a side note, i'm also getting polk momo's for the front and rear (components in the front) along with a pioneer AVH-P4000 double din. i'm hoping to be really satisfied with this setup
Old May 7, 2008 | 09:47 PM
To look stock, you need glass or bondo and paint, not carpeted.
Old May 7, 2008 | 10:06 PM
Zdeuce4's Avatar
its not going to be any bigger than the stock box, so it'll still sit on the side of the trunk.. its a shallow 10 not a huge 12.. having a painted box would look stock?
Old May 7, 2008 | 10:28 PM
Closer to stock. Since the stock box is black plastic, if you paint it with a non-gloss black it will look pretty close.
Old May 7, 2008 | 10:31 PM
Zdeuce4's Avatar
lol most people dont even recognize cobalts as having one, and since its so small and will blend in... idk , ill just post up pics when its done..
Old May 7, 2008 | 10:34 PM
Well if you get it carpeted, make sure you match the stock carpet.
Old May 8, 2008 | 12:57 AM
EmperorJJ1's Avatar
if your doing a custom fiberglass box thats a whole new animal... id say go carpeted
Old May 8, 2008 | 01:03 AM
Zdeuce4's Avatar
yup carpeted seems easier anyway, wut are ur thoughts on the speakers im goin with?
Old May 8, 2008 | 01:10 AM
EmperorJJ1's Avatar
personally every kicker ive dealt with was loud but sounded "bad" a sealed box is going to limit output somewhat but might give u slightly better sound quality (but dont expect anything great) Honestly for a starter small system you will be fine. Also when ur in the seats not hearing them from the trunk they soudn a bit better. I bet you will really like it... worlds better then stock
Old May 8, 2008 | 01:43 AM
Zdeuce4's Avatar
see its weird with me, i like loud, but not if its like ring my ears loud... I found out about the setup by playing with it at Circuit City with the AVic-D3 as the headunit. I know the AVH-p4000 is no D3, but im sure it will be able to give me wut i want. I had polk DB's in my cavy so im anxious to hear how the momos do.
Old May 8, 2008 | 01:52 AM
EmperorJJ1's Avatar
door speakers?
Old May 8, 2008 | 01:57 AM
Zdeuce4's Avatar
door speakers?
yea 6.5s in the front and 6x9s in the back.. in the cavy i had 4x6s in front and 6x9s in the back but they were dbs. way better than the stock crap i had.
Aug 29, 2015 03:11 PM
jeweler54
Dec 4, 2006 07:00 AM
cobalt2k5
Nov 29, 2006 02:12 PM
cobalt2k5
Nov 23, 2006 04:44 PM
