Led map lights staying on
Old Apr 6, 2015 | 09:08 PM
smitzk01's Avatar
Hello, as the title states I just installed led map lights and they never really go out. They become super super dim but definitely stay on. I also replaced my license plate light and that does not do the same thing.
I got T10 led bulbs from eBay.
I will check and see how much voltage is being sent to the map lights tomorrow with a voltmeter but I was just seeing if anyone else has run into this.
Thanks!
Old Apr 6, 2015 | 09:58 PM
jcobaltss's Avatar
Normal for cheap led's I've had mine for 6 months and no issues
Old Apr 6, 2015 | 10:20 PM
chevygirl2006's Avatar
No. It's because they need a resistor soldered in. If not, they will always have constant power. Regardless it won't drain your battery. To solve the issue solder in a 1ohm resistor into each led.
Old Apr 6, 2015 | 10:42 PM
smitzk01's Avatar
So the license plate bulb is an exception? You said it won't drain my battery regardless, i assume this is from experience? Draining my battery was my main concern. I just put a new battery in it when I got it out of storage a few weeks ago. When you say solder an ohm resistor into the led do you mean along one lead?
Old Apr 6, 2015 | 11:07 PM
sstcsfsd's Avatar
i have cheap led map lights from amazon, they stay dimly lit at all times. Doesn't bother me. Sat for 4 months all winter this way and did not drain the battery
Old Apr 6, 2015 | 11:52 PM
No it won't drain your battery. I decided to have resistors put in because I didn't want a light constantly on inside of my car.
Old Apr 7, 2015 | 01:32 AM
smitzk01's Avatar
Thanks to both of you!
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
