Lights dimming when braking, rolling down window
Old Aug 3, 2013 | 12:34 PM
Pitbull2o08's Avatar
SO my interior, and headlights were dimming last night as I was driving 500 miles to the Carolinas. Whenever I put my brakes on, rolled up/down the windows or even once when the radio was turned up. I have HIDs in the fogs and HID headlights with relay. Never had this issue before and it seemed to go away when i was in the city, then come back again and stalled my car. I was thinking the alternator might be on it's way out. Any other ideas, i'd appreciate it.
Old Aug 5, 2013 | 06:16 PM
EmperorJJ1's Avatar
ya probably the alt but id check the battery as well it might be fried if the alt isnt charging properly
Old Aug 5, 2013 | 06:41 PM
Thanks man, it's happening now driving home. I'll turn on my HID headlights and the car shuts off, on the highway! Now nothing is happening and everything's cool. It's intermittent. I'll get them both checked at autozone for free when I'm home
Old Aug 5, 2013 | 11:36 PM
They checked the battery, alternator and starter for ***** and gigs, everything checked out good. I'm stumped.
EmperorJJ1's Avatar
are the connections at the battery tight? how about the post under the hood?
Old Aug 6, 2013 | 02:12 AM
I will tomorrow morning
Old Aug 6, 2013 | 02:16 AM
ls1fbody's Avatar
Haz l33t wheelz.
My car started having issues similar to this. So I sold it haha.
Sorry I'm no help, but good luck.
I think a lot of people have traced similar door lock and window issues to the drivers side master window switch cluster. Replace that, bingo.
Old Aug 6, 2013 | 02:37 AM
It's more of an electrical load taxing the system that a specific switch. The guys that tested my battery and alternator both said to check connections first. So I'm going to check the battery. What were the other large powe connections? The front fuse box under the hood? Should I check the alternator cables?
Old Aug 7, 2013 | 12:26 PM
I had the battery and alternator checked, everything was within spec. I took the battery out, cleaned the terminals and the battery, and reclamped it down tight with some grease. I still have the issue. What else should I do?
Old Aug 7, 2013 | 11:10 PM
EmperorJJ1's Avatar
damn. the only other thing you could check is the connections at the alt and PCM/BCM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
