lights going haywire in dash
Old Nov 23, 2009 | 09:46 PM
rkenny97's Avatar
ok so i hooked a sytem up in my car last night and think something came loose in my car. cause after just about a couple hours my car went nuts, the dash lights stay on but gauges do not,radio is off, and abs light, traction light, e brake light, are all on, then after a while it all might come back on but just for a sec. ive unhooked the sytem and it still does it, anyone have this problem or any ideas thanks
OKSO THESYTEMHADNOTHINGTODO WITH IT THESYSTEM WAS OUT BUT WAS STILL DOING IT, THEN IT JUST STOPPED. NOW ALMOST A MONTH LATER ITS DOING IT AGAIN. BUT I GOTA VIDEO THIS TIME.
Old Nov 23, 2009 | 09:50 PM
Cefaln452's Avatar
sounds like you may have tapped the wrong wire and fried the BCM
Old Nov 23, 2009 | 10:10 PM
rkenny97's Avatar
dnt wanna sound dumb but whats the bcm
Old Nov 23, 2009 | 10:17 PM
Cefaln452's Avatar
body controll mod. Means that the symptoms that you are having are controlled by the bcm and if that was damaged that is what can happen... the fix is replacing the bcm and thats upwards of 2xxx
Old Nov 23, 2009 | 10:20 PM
oowah's Avatar
I did something similar while hooking up some lights 2 weeks ago. I was tapping into a fuse for a relay coil and must have brushed a fuse without noticing or something.... all my stuff went apeshit -gauges sweeping etc.
Unhook your battery, take it to the dealer and they'll fix it without replacing the module (unless you actually fried it outright)
So don't get too worried just yet man.
Cost me like $180 which is way better than I expected since a BCM is like $600 or something plus labour. They said they just disconnected the module, discharged the wiring, hooked it all back up and had to boost my battery and it was golden.
Old Nov 23, 2009 | 10:26 PM
rkenny97's Avatar
so what does the bcm actually do? and you guys dont think its a loose ground do u
Old Nov 23, 2009 | 10:27 PM
Cefaln452's Avatar
it is what controls all the cars functions, lights, abs etc
Old Nov 23, 2009 | 10:28 PM
rkenny97's Avatar
oh gotya.is it like a sensor if so where is it
Old Nov 23, 2009 | 10:29 PM
oowah's Avatar
Body control module is a computer that controls all of the inputs and outputs of the accessories and things in your car (for example, the signals for your gauge lights, gauge needles, radio, doorlocks, headlight signals, all buttons and switches in the car).
If your gauges are "sweeping" back and forth, or if the lights are intermittently flashing on and off....... you probably messed up your BCM.
If you mean a loose ground for your amp, then that would likely only affect your system not working properly - not your instrument panel.
Old Nov 24, 2009 | 01:27 AM
EmperorJJ1's Avatar
put everything back to stock in terms of functionality and see what happens.... could have fried the bcm but maybe not just go back to step one and see if u can get the problem to go away
Old Dec 3, 2009 | 07:19 PM
rkenny97's Avatar
backfrom the dead it quit then now almost a month later its doing it again but i got a vid while i was on my way home.
Old Dec 3, 2009 | 07:23 PM
~Mike~'s Avatar
so post the vid lol
I'm gonna go with you messed up ur BCM man. I would take that system out and take the car back to the dealer provided you have warranty still. Easiest route to go man...and cheapest
Old Dec 3, 2009 | 07:25 PM
rkenny97's Avatar
vid is up systemhas been out and i dnt have a warrenty.im at 41k miles
Old Dec 3, 2009 | 11:55 PM
Cefaln452's Avatar
your BCM is fucked... i mean FUCKED
Old Dec 4, 2009 | 07:47 PM
rkenny97's Avatar
Yup sure is took it the dealer. Do u know how hard it is to put a new one in? Does it matter the model one came out of?
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
