line converter
Old Dec 28, 2005 | 06:29 PM
dnbguy86's Avatar
line converter
I bought a line converter, and i hooked it up and ran my speakers wires and so on. Then for my remote wire i ran a wire to the underhood fuse box and tied it into my cigar fuse, only thing i could think of at the moment that still see's 12v in the acc position. Now, my question is i get a humming noise and low to moderate playin levels, i believe its because the wire is going though some RFI disturbances or something? what else could i use as a source for a for 12v reference for my amp ? thanxs...
Old Dec 28, 2005 | 06:44 PM
pclear9061's Avatar
you can get a filter and put it inline with your power that should take care of the humming
Old Dec 28, 2005 | 06:51 PM
hardtocope's Avatar
hook it up to the windshield wiper fuse #15 in the passenger side fuse box... this is what crutchfield recommends and it's the easiest location.
what kind of amp and sub did u hook it up to?
Old Dec 28, 2005 | 07:24 PM
dnbguy86's Avatar
guy from work sold me a quantum 1000watt amp or something close to that for cheap, so im using that now. puts out nice power but it just sounds like i have a ghetto system when it whines and and low playing levels. i guess i can try the windshield wiper fuse and see how that goes. i already tried to use a ground isolator, but to no success...
Old Dec 28, 2005 | 11:41 PM
hardtocope's Avatar
what kind of line output converter are u using
Old Dec 29, 2005 | 12:05 AM
tiny's Avatar
id upgrade the system to quality components
Old Dec 29, 2005 | 11:43 PM
dnbguy86's Avatar
I have quality components, such as the rca cbles, amp(sony), subs(sony), so the quality is not the problem, i think it has to do wit hthe unshielded wire i ran to the underhood fuse box...im gonna try to re route it to see if it gets less interference
Old Dec 29, 2005 | 11:49 PM
hardtocope's Avatar
have the bass down on my factory headunit all the way down because i have factory speakers and i don't want to blow them.. i have a alpine amp and jl sub that i have but not installed yet.. since the bass on the headunit is down i'm just curiuos if the amp will be reading to low of singal from the lineoutput converter. i don't think the amp will have enough singal to read??
Old Dec 30, 2005 | 08:01 PM
hardtocope's Avatar
have u tried the winshield wiper fuse yet?
Old Jan 1, 2006 | 08:02 PM
dnbguy86's Avatar
Naw, havent tried to the fuse yet, but im gonna hold off on the stereo right now as i think id like a drop, and exhaust right now more than the system. The rockford fosgate 6x9 replacements i put in sound good enough
Old Jan 3, 2006 | 10:34 AM
ORT's Avatar
ORT
Maybe check your grounds too? An uncovered wire shouldn't really produce that much noise if, if any noise at all. Also you could run the wire to your door pins. Thats what I have my headunit ran to Everything turns off when i open the door :-) haha its pretty nifty.
Old Jan 7, 2006 | 06:06 PM
dnbguy86's Avatar
Well, i installed my system again, and found out using the cigar(lighter) fuse i believe it called, was causing my amp to have interference because after the key was turned off the RAP feature keep sending power to the amp, and i think it was gettin some weird signal. Anywho, now the problem i have no is i cannot find a fuse that lets me turn on my amp in the ACC position on the igniton cyclinder. all i found are ones that have to have the ON position to work ? anybody have any ideas on what other 12v source i can use ?
Old Jan 11, 2006 | 07:48 AM
ORT's Avatar
ORT
Like i said.....Your door pins. Thats what I use and it works like a charm
Old Jan 11, 2006 | 08:12 AM
Brian MP5T's Avatar
Yeah but that might make a terrible noise with the wipers on...
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Hill1513
Sep 21, 2015 07:18 AM
Cobe
Sep 19, 2015 11:04 AM
