metra harness
Old Jan 31, 2010 | 01:32 AM
NOLAGSS's Avatar
metra harness
best buy gave me the wrong harness they gave me a metra 2102 for a saturn ion.. it is blue is it possible to use this in my 06 ss
Old Jan 31, 2010 | 02:00 AM
Spun's Avatar
I not sure if its possible, but I know if it is, the harness needs to be re-pined first.
The harness you want is the Metra 70-2103.
I'm pretty sure your going to need to run a ACC (red power wire) line from the fuse box cuz there is no 12 volt line on the car side of the stereo harness, most of the aftermarket harness have the hardware you'll need included in the package
Old Jan 31, 2010 | 09:24 PM
NOLAGSS's Avatar
well i went to my local advanced auto parts store and they have a metra adapter with the fuse panel wire.. problem is is that they have there part number on it not the 2103 number. it says its for ??-08 gm vehichles would this be the correct one
Old Feb 1, 2010 | 12:23 AM
EmperorJJ1's Avatar
is it blue or gray... the 2102 might work but the speaker wires would be reversed
Old Feb 1, 2010 | 01:05 AM
NOLAGSS's Avatar
it was gray i do believe
Old Feb 1, 2010 | 01:17 AM
EmperorJJ1's Avatar
wont work
Old Feb 1, 2010 | 01:22 AM
NOLAGSS's Avatar
ok i still have the 2102 im wondering whats different from the 2103 i can not find pin outs of the two to save my life
Old Feb 1, 2010 | 01:30 AM
EmperorJJ1's Avatar
like i said i think the only difference is the speaker wires swapped
Old Feb 1, 2010 | 04:40 PM
NOLAGSS's Avatar
i went to my work where i have access to michel on demand and pulled the color coding info on the factory wires the wired the up correctly to the 70-2102 to my surprise none of the wires were mixed matched or anything. just connected color to color and everything worked perfect
Pasierbek
Dec 10, 2015 07:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
jcobaltss
Oct 10, 2015 10:14 AM
Jeffwills14
Sep 6, 2015 06:52 PM
