Is my amp dead?
Old Oct 29, 2012 | 01:45 PM
Jesse's Avatar
Is my amp dead?
My amp won't power on. I'm pissed. I listened to a song on the way home from job #1. Got home, ate something, checked facebook, then went to job #2 and no music would play. It's not the radio, which works fine. Remote wire is fine, ALL fuses are good, and the amp has good power/ground. The fuse on the power line is good too.
What do I do? Anything else I can check? It's a 2011 Soundstream Rubicon 400w 4 channel amp. If It's not salvageable I'm buying an Alpine digital amp.
Old Oct 30, 2012 | 01:49 AM
Jesse's Avatar
Anyone? Lol. Alpine PDX-V9 it is.
Old Oct 30, 2012 | 02:02 AM
duffman11's Avatar
Sell it and buy a Turbo kit. Other than that I am pretty useless. Sorry. Free Bump.
Old Oct 30, 2012 | 02:17 AM
EmperorJJ1's Avatar
does it light up? is it getting signal from the RCA's
Old Oct 30, 2012 | 03:19 AM
Jesse's Avatar
It will not light up, and yes it is getting a signal from the RCAs. I also checked the remote wire and it is fine. Same with power and ground wires.
Old Oct 30, 2012 | 03:23 AM
Ericleeschroeder's Avatar
If it won't light up and all connections are good I'd say it died. It seems odd though considering it was okay and died while not in use. I guess try regrounding or replacing the fuses even if they look fine and see if that helps.
Old Oct 30, 2012 | 03:31 AM
Jesse's Avatar
I'll do that after work tomorrow then. I need to buy a 5lb hammer to remove my strut bolts anyway. Maybe I'll put in some subs. A friend has two 10" Skar audio subs in a custom ported box for sale...
Old Oct 30, 2012 | 04:15 AM
EmperorJJ1's Avatar
define checked the wires and they are fine? fuses in the amp blown?
Old Oct 30, 2012 | 12:51 PM
Jesse's Avatar
I took the radio out and ran the length of the wires checking for kinks, cuts, fraying, open surfaces, etc... Also got my multimeter involved where I could. I know I'm getting juice. I know I'm getting a signal from the remote wire. I know I have a good ground. I checked all three fuses on the amp and they are in tact.
EDIT: I just hooked up an amp a friend has and it works fine. So it has to be something wrong with the amp. I'm not too mad, the amp I have now only cost $150.
Old Oct 30, 2012 | 01:52 PM
EmperorJJ1's Avatar
ah multi meter is what i was hoping for... well if thats the case shes gonners
Old Oct 30, 2012 | 02:01 PM
Jesse's Avatar
Well that sucks. Thanks for the help guys. Time to save for new goodies.
The Rookie24
Jan 20, 2016 05:14 PM
chefhhr
Oct 26, 2015 10:36 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
c_m_shooter
Sep 27, 2015 04:40 PM
