Need Help
Old Nov 12, 2012 | 10:39 PM
2007blkSS's Avatar
Need Help
So i have every wire connected right into the harness and everything the headunit powers up and functions and except no sound coming out of the speakers, i even rewired them and tried again and still no sound at all, would anyone know what this is?
Old Nov 13, 2012 | 12:03 AM
StevoElSupremo's Avatar
Yeah... I had the same issue as you, did everything right and no sound either, turned out to be some stupid pinkish colour wire I had to tap into
http://www.***************/forums/au...-no-sound.html
check that link, its some bluish coloured wire that I tapped to the pink one and everything was perfect after that.
ugh stupid .net wont let me link www.y o u r c o b a l t links...
wwell anywhoo it was a blue wire OUT on the deck that I tapped to a PINK wire on the factory harness to activate the factory amp.. worked for me and countless others who had the same issue as you try it out, tell me if it works.
Old Nov 13, 2012 | 01:07 AM
2007blkSS's Avatar
Would be so much better if someone could get me a picture >.< thanks tho !!
Old Nov 13, 2012 | 03:24 AM
EmperorJJ1's Avatar
iight lets walk you thru it then
what harness are u using?
Old Nov 13, 2012 | 07:19 AM
2007blkSS's Avatar
Scosche GM13SR
Old Nov 14, 2012 | 01:11 AM
EmperorJJ1's Avatar
is there a blue/white wire in that harness? if yes is it hooked up to the blue white wire on the radio?
Old Nov 14, 2012 | 01:32 AM
2007blkSS's Avatar
Already got it all done
Old Nov 14, 2012 | 01:54 AM
EmperorJJ1's Avatar
ok cool. not so hard once u know what the prob is
