need help with my hids
Old Mar 12, 2008 | 09:26 AM
06CobaltssOrange's Avatar
So i have hids and i have the lows installed but i cant seem to figure out the high beams. Theres one yellow wire and i dont understand where it goes because i live in the middle of nowhere and i need high beams im just confused how theese would work.
Old Mar 12, 2008 | 09:41 AM
HidKidSS's Avatar
a yellow wire? never had a yellow wire on any of my hid kits ive had on my cobalt but 1st off start off with looking at the box that the hids came in becouse you might have just ordered the 1 beam setting youll know if its the hi an low beam setting if it says BI-HID
hope that helped a little
Old Mar 12, 2008 | 12:23 PM
yes it does and has like two bulbs for each like light but there together i just dont understand why hooking them up normally wont work the high beam.
can someone actually make a like how to on here how to install them all on there own. because i would like to i guess just reinstall with someone says as a high beam with the hids also.
Last edited by 06CobaltssOrange; Mar 12, 2008 at 12:23 PM. Reason: Automerged Doublepost
Old Mar 14, 2008 | 11:01 AM
to the top still have no high beams
Old Mar 15, 2008 | 12:41 PM
musifreak190's Avatar
You have to wire in a diode from your stock high beam wire to the ballast + in i believe...Deffinetely do some research on it.
Old Mar 16, 2008 | 11:15 AM
well i looked and the stock harness has 3 prongs 1 for low beam 1 for ground and 1 for high beam and the ballast and the harness only has 2 1 for low beam and 1 for ground. theres no third anywhere. So i have the hids capability to run high beam but it wont run it.
Old Mar 17, 2008 | 11:57 AM
yeah so are mine, they're bi-xenon...there is a way to do it...its something with the diode...I would be trying to figure it out myself if my car wasnt in the body shop. Im gonna talk to me friend who works at an audio place.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
juandirtymessican
Oct 27, 2012 10:41 PM
