Need help picking an amp...I'm a stereo n00bie
Old Feb 24, 2010 | 06:11 PM
JL-KA's Avatar
What amp should I use for my speakers. Doesn't have to be Kicker.
Stock HU
Kicker 10 " CVX with amp(not sure which one...been too long)
Kicker KS Components up front:
Specs:
Model KS650
Woofer (in., cm) 6-1/2, 16.5
Tweeter (in., cm) 3/4, 2.0
Impedance (Ohms) 4
Max Rec Amp Power (watts PEAK/RMS)* 195/65
Sensitivity (dB 1w/1m) 90
Frequency Response (Hz) 40-21k
Mounting Hole Diameter (in., cm) 5-5/8, 14.3
Mounting Depth (in., cm) 2-1/8, 5.4
Grilles Yes
Kicker KS 6x9s in rear
Specs:
Model KS6930
Woofer (in., cm) 6x9, 16x23.0
Mid (in., cm) 1, 2.5
Impedance (Ohms) 4
Max Rec Amp Power (watts PEAK/RMS)* 300/100
Sensitivity (dB 1w/1m) 92
Frequency Response (Hz) 30-21k
Mounting Hole Diameter (in., cm) 6x8-9/16, 15.2x21.7
Mounting Depth (in., cm) 3-3/16, 8.1
Grilles Yes
Old Feb 24, 2010 | 06:42 PM
dakotaspeir's Avatar
#cobalthoes
Id say a rockford fostage p400.4
Old Feb 24, 2010 | 07:19 PM
JL-KA's Avatar
Thanks.
Why that one over the t400.4?
Bump for more opinions.
Old Feb 24, 2010 | 08:47 PM
#cobalthoes
I have just always heard p is better than t when it comes to rockford.. Even tho the p is rated about 10 watts less you can't even notice that..
Old Feb 25, 2010 | 12:14 AM
TheWarHam's Avatar
Generally an amp is an amp if its made by a well-known company, but I would go with the
Kenwood KAC-8405
Generally I stick with Kenwood amps because I have a Kenwood amp powering the speakers in the other room - its regularly used and from 1976 and it still rocks. And only one LED is out, ha.
Its also cheap.
Old Feb 25, 2010 | 12:38 AM
JL-KA's Avatar
So one person saying a 400w amp and the other a 600w amp.
I always thought you were supposed to match the RMS of your speakers to your amp
Old Feb 25, 2010 | 01:34 PM
JL-KA's Avatar
bump bump bump
Old Feb 25, 2010 | 06:54 PM
TheWarHam's Avatar
Generally you want the rms to match. The kenwood was a little closer. I would get wattage higher than the front because you could always "fade" to the back so youre not overpowering the front and youre getting a little closer to the back speaker's needed power.
But really 10 or so watts isnt going to matter. Unless youre pushing your speakers (and ears) to the absolute limit 50-70 watts should be fine. Because to get a little higher your wallet gets drastically skinnier.
Old Feb 25, 2010 | 06:55 PM
CordiaDOHC's Avatar
Look up SunDown Audio.
Old Feb 26, 2010 | 02:26 AM
EmperorJJ1's Avatar
are u looking to power all 4 speakers and the sub with a single amp or is it just for the 4 vocal speakers? and do u want fade from front to back?
Old Feb 26, 2010 | 02:43 AM
09-cobalt-lt's Avatar
two letters, JL
Old Feb 26, 2010 | 02:50 AM
CordiaDOHC's Avatar
Originally Posted by 09-cobalt-lt
two letters, JL
JL is overrated and over priced. Period.
Zapco
Hertz
Dynaudio
Treo
Sundown Audio
Digital Designs
Would all be brands id chose over JL! (theres some spl and some sq in there..)
Old Feb 26, 2010 | 02:56 AM
Zapco
Hertz
Dynaudio
Treo
Sundown Audio
Digital Designs
that's your opinion. for the money I couldn't find anything better than my old setup(JL subs, amp and Hertz speakers)
Old Feb 26, 2010 | 07:16 PM
JL-KA's Avatar
I'm content with the amp that's on the sub right now however if it would be easier(as far as install goes) I wouldn't be opposed to taking that out and just running one amp for all of them. I generally leave it at a 50/50 split.
Old Feb 26, 2010 | 11:46 PM
EmperorJJ1's Avatar
pretty much any standard 4 channel that does anywhere from 50w -80w rms is what id go for... for the most part any company listed would work well for you man. ive had alot of experience with the p4004 and if your looking at fosgate i would do it over the power series T
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 07:39 AM
HEATON
Oct 16, 2015 07:21 PM
riceburner
Oct 2, 2015 05:47 PM
Bohb
Sep 27, 2015 09:11 PM
