need some help!
Old Apr 14, 2009 | 02:23 AM
timmhimself's Avatar
need some help!
i've installed aftermarket head units and speakers quite a few times, so i'm not completely ignorant to car audio. but i'm new to amps and subs. i just got 2 10" MTX road thunder subs, and a 300 watt jensen amp from a buddy of mine and i need to know what exactly i need to hook it all up with a stock HU.
i'm assuming a speaker level converter of some sort for the wires spliced from the 6x9's, a power cable with an inline fuse, and speaker wire but i wanna know for sure i have absolutely everything i need so i don't get it all together then fry my amp and/or blow my subs.
also where did you guys wire up your amp so it shuts off with the car just straight to a 12v in the fuse box that shuts off with the car?
they're going in an '07 ls.
i know the RMS of the amp isn't quite enough for the subs but the price was right so i'll deal till i have the money for a better amp, this is a temporary set up till i get the cash for the system i want.
Old Apr 14, 2009 | 01:01 PM
bump.
no one?
Old Apr 14, 2009 | 01:23 PM
dthomp2366's Avatar
If the amp accepts speaker level input, do that from the 6x9s. If it doesn't then line out converter to RCA.
Old Apr 14, 2009 | 02:14 PM
brickloaf's Avatar
just buy a amp kit and that will have pretty much everything you need (except maybe RCA's)
and you already said speaker wire/line out converter
Old Apr 14, 2009 | 09:59 PM
alright thanks guys.
Old Apr 15, 2009 | 08:49 AM
EmperorJJ1's Avatar
6ft rcas, power/ground wire (i would buy off a spool if you have the chance. 6ft of each so you can ground straight to the batt) fuseholder/fuse, remote wire, speaker wire, line output converter, 10mm nut
Old Apr 15, 2009 | 04:19 PM
thanks emp!
i have some shopping to do.
