Need some technical assistance
Old Oct 30, 2006 | 01:11 PM
LSJ PUP's Avatar
Exclamation Need some technical assistance
I took apart a hansfree headset for my phone to rewire it and once I cut the microphone wire, I reconnected it and it doesn't work for some reason. How can this be? The is a white wire and a bare wire and both are connected correctly?
I have been going crazy trying to figure this out for 12 hours now.
TIA
Old Oct 30, 2006 | 01:19 PM
Brian MP5T's Avatar
Take it to a Pro...
Old Oct 30, 2006 | 01:24 PM
StinkBOMB's Avatar
Did you burn the coating off of the white wire and the bare one? They put a protective coating(and not the obvious plastic one) on these wires to keep them from grounding each other. Unless you burn it off, and solder it back and then prevent the wiring from touching each other you aren't going to get it to work. A picture would be great, but it sounds to me like you're going to need a few more tools to do the job.
Old Oct 30, 2006 | 01:28 PM
LSJ PUP's Avatar
No actually I have just about every tool I could possibly need including a soldering iron. I'm not sure if there is a coating on these wires, but I will definitely go ahead and solder them to one another or a small circuit board to find out. Excellent thought though. Thanks. I know the speaker output wires have a coating on them because one is red and one is blue.
I'll give it a try.
Old Oct 30, 2006 | 01:29 PM
LSJ PUP's Avatar
Originally Posted by Brian MP5T
Take it to a Pro...
Yeah, because a pro can do a great deal more than I can...
Old Oct 30, 2006 | 01:56 PM
LSJ PUP's Avatar
Thanks a great deal bro. That was the problem. I went ahead and coated the ends with solder and tapped the leads together and it worked great. The simple mic amp I built last night also works great. I'm gonna upload some pics so you guys can see my success. Thanks for all the help.
-Josh
Old Nov 1, 2006 | 10:17 AM
Bandit2941's Avatar
-Josh
So the volume is good now?
I don't think a pro would have been able to help you. Sounds like you are more then capable of doing this stuff yourself. You should write up a how-to when you're done...
06MetallicBalt
Jul 20, 2025 08:47 PM
satisfied
Oct 19, 2015 12:35 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
