No Dash Lights!
Old Feb 3, 2011 | 10:23 AM
ezekielguy86's Avatar
No Dash Lights!
OK so I put my retrofits in yestursay everything works fine except I left my angel eyes unhooked since I needed a soidering gun. Now everything works except my speedo, air control, window lights. I checked all the small fuses and all of them were good. I even swapped out the dimmer switch since I had another and no dice. Any help would great thanks.
Old Feb 3, 2011 | 10:39 AM
SuperChargedMA's Avatar
I had problems too.. but nothing like this haha... did you do some crazy wiring? bump for ya
Old Feb 3, 2011 | 10:58 AM
I spliced into the ground that goes to the little bulbs behind the reflectors in the headlights. I didn't put those bulbs back in either if that's a problem
Old Feb 3, 2011 | 01:01 PM
EmperorJJ1's Avatar
hmm sounds like a gm lan problem. id take out the lights and see if that changes anything
Old Feb 3, 2011 | 01:30 PM
They headlights? And try with nothing plugged in
Old Feb 4, 2011 | 03:44 AM
EmperorJJ1's Avatar
right unplug the headlights and see if it goes back to normal. If it doesnt check all the fuses in both fuse boxes (probably not but wont hurt)
Old Feb 4, 2011 | 04:05 AM
MastaShaKe_88's Avatar
parkin lamp fuse? I don't know why yer Hvac lights went out, i thought that was on another circuit... sounds like jus some bad shiiiit...
jus make sure yer wires are all tapped in right.. I don't know why you'd have to solder any wires for you Halos but... do watcha wanna do
but do like ole boy said an unplug em, check the wiring..
Bad wirin in my taillights blew my parking lamp fuse,dash cluster went out.
Bad wirin in my headlights did the same thing few months later
check your parkin lamp fuse(fuse box under hood), and your cluster fuse(passenger side kick plate I think they call it?..)
Cluster's a 10 amp (ithink) an prk Lmps a 20 amp
Old Feb 4, 2011 | 01:49 PM
We pulled the lights out still didn't work. Put them back now they are good Idk. I'm just glad they work.
I have to soider I'm halos to some power source. What are you guys hooking them too?
Old Feb 4, 2011 | 02:09 PM
I didn't like how pinkish mine looked so painted part of em so it looks like mean eyes I likes it tho...
But i tapped em into my parkin lights(brown wire) an the negative to a blk wire
Old Feb 4, 2011 | 05:16 PM
That's what I plan to do is wire them to the parking light I just want to soider the wires together
Old Feb 5, 2011 | 05:24 PM
I have the demon eyes from streetracinazian and I ran mine to the inside and put it through the center console to a switch that runs off of the auxilary port
Old Feb 7, 2011 | 05:19 AM
slobalt08's Avatar
parking lights fuse
Old Feb 7, 2011 | 06:03 AM
D_sean257's Avatar
Originally Posted by slobalt08
parking lights fuse
^^ this.. Had this problem before.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
