No Sound after new stereo Install.
Old Aug 2, 2006 | 09:09 AM
BooSSted's Avatar
I just put in my Kenwood indash DVD setup and I am not getting any sound out of the speakers at all. I used the proper Metra wiring harness and everything looks to be hooked up right. Is there something that I need to do to bypass the factory amp or something?
Old Aug 2, 2006 | 09:15 AM
sunfirejoe's Avatar
theres 2 blue wires if your running amps thjat have to be connected as a remote, if you dont u jsut have to connect your 1, its like a remote for your stock amp
Old Aug 2, 2006 | 09:32 AM
BooSSted's Avatar
Ok, those are the blue wires in the factory harness?
Old Aug 2, 2006 | 10:11 AM
BooSSted's Avatar
Tried that, didn't work.
Old Aug 2, 2006 | 11:46 AM
kuhockey29's Avatar
u sed the metra harness and i had to repin it, the speaker pins weren't in the right place. maybe that could be the problem
Old Aug 2, 2006 | 12:04 PM
BooSSted's Avatar
Yeah that would probably do it, haha.
What year is your car? Does it have the 7 speaker Pioneer system? Did you use Metra part # 70-2103?
Old Aug 2, 2006 | 12:35 PM
slamedham's Avatar
yeah what joe said. i ran into the same problem. hooked it up to my remote wire and presto i had music.
Old Aug 2, 2006 | 05:47 PM
BooSSted's Avatar
Which Blue wire did you use? There are 2 one on the left and one on the right. I tried them both but got nothing
Old Aug 2, 2006 | 08:01 PM
BooSSted's Avatar
Talked to my friend (Installer) today and he said I need to bypass the factory amp.
Old Aug 3, 2006 | 12:42 AM
slamedham's Avatar
ummm no you don't. dude i JUST did my install not more then a a month ago.
i bought the GM10 schoche wireing harness. 169.00 or something like that.
i forgot to hook ONE wire up and it was the wire for the amp turn on. after i hooked it up i had music. i didn't have to bypass anything.
trust me man. the system in my cobalt isn't stock any more. i have already been to 2 shows with my system. got 1st at one and 2nd at another.
Old Aug 3, 2006 | 01:20 AM
iLLmaTic3s's Avatar
if u are just addin a radio to the pionner setup or base set up..u have to hook all blue wires together on the radio harness and the wiring harness that plugs into the stock wiring...if pin connection is wrong..u can just simple run a new wire or at times hook it onto the accesory wire(red).
Old Aug 3, 2006 | 02:06 AM
BooSSted's Avatar
I have tried hooking the blue wires together and I get nothing. I used the Remote wire from the new deck and I put it to both of the wires and then all of them at the same time and I still got nothing.
I talked to Crutchfield on this one too and they also said I need to bypass the stock amp.
I don't know what else to do, I tried what you guys are suggesting but it still won't work. I am dropping the car off at my friends shop on Friday and he is going to get it working. I'll let you know how it turns out.
Old Aug 3, 2006 | 09:11 AM
iLLmaTic3s's Avatar
i dont think so. u have the pioneer setup? if u bypass the amp its gonna sound ok cuz then ur not using that amp for those fact. speakers. hmmm
Old Aug 3, 2006 | 09:56 AM
e to the x's Avatar
You have to have hooked something up wrong, or your new deck is not working properly. I hope your friend is doing that for free. I jsut hope you didn't short something if you did hook a wire up wrong.
Old Aug 3, 2006 | 11:05 AM
BooSSted's Avatar
The deck works fine. I hooked up a speaker that I had sitting around in the garage right from the deck and it worked. We are going to check the wiring harness first to make sure everything lines up. If that's all good (Which I am sure it is) then he is just going to bypass the amp.
Old Aug 4, 2006 | 12:19 AM
iLLmaTic3s's Avatar
i hope for the best..also check ur fuses. i hope u dont have to bypass the amp...that will suck
Old Aug 4, 2006 | 01:06 AM
Grimlakin's Avatar
Ummmm can we get a pic of the deck when it is working? I want to get a gps/dvd playing deck myself.
Old Aug 9, 2006 | 11:46 AM
SymbioteLT's Avatar
I had the same problem, no sound. rechecked everything and it works now, with factory amp
Old Aug 13, 2006 | 09:09 AM
firesting's Avatar
Im having the same problem! Hooked everything up, unit turns on, but no sound. For the blue wires, all I have is a blue/white wire coming from my pioneer deck and a solid blue wire from the harness? Is that what I need to hook up together to get sound?
Old Aug 13, 2006 | 09:13 AM
firesting's Avatar
Also, could it be possible that my unit doesnt turn on anymore because its not grounded? Which wire is that again, black or can it be the black/white one?
Old Aug 13, 2006 | 09:49 AM
firesting's Avatar
come on plzzz help!! lol
Old Aug 13, 2006 | 10:20 AM
StinkBOMB's Avatar
If I was there I could probably help, could snap a pic and post it, I need a visual.
Old Aug 13, 2006 | 11:33 AM
leroy's Avatar
i just cant remember what wire it was a pic and i could tell i would pull mine out but the clips in the trim pices are a bitch
Old Aug 13, 2006 | 11:56 AM
senior_brown's Avatar
i got the metra kit for 04 malibu, connect the deck's remote turn on wire to the metra harness power antenna wire it willwork, i ran into the same problem
Old Aug 13, 2006 | 03:04 PM
firesting's Avatar
Ok now my deck wont even turn on!!! WTF i dunno whats happening lol! I'll post pictures as soon as possible!!
