Pioneer Sub? Amp? Work?
Old Mar 27, 2007 | 12:32 PM
CobaltSS[303]'s Avatar
K, here it is. Can i hook a aftermarket amp to the stock sub or would it blow. i didnt know the specs on the stock pioneer sub. it doesnt look like it could handle much but was just curious.
Last edited by CobaltSS[303]; Mar 27, 2007 at 12:32 PM. Reason: Automerged Doublepost
Old Mar 27, 2007 | 05:12 PM
Johnboy12358's Avatar
My bet is you would probably be overpowering it, but I dont have any real idea
Old Mar 28, 2007 | 04:10 AM
EmperorJJ1's Avatar
depends on the amp size... while it could be done if you were to do so id invest in an amp thats specs are head on with an aftermarket sub... that way if you do blow it you have enough power for the aftermarket one and you know exactly which sub to buy
Old Mar 28, 2007 | 08:00 AM
Well i was just curious. i know it wont be as loud as my previous systems. At one time i had 4 12" subs, then 1 12" sub, 2 10" subs, 1 15", and 2 12" subs that i recently blew. I think im gonna get some w7's, but not sure
Old Mar 28, 2007 | 08:30 AM
Shermen's Avatar
no you can not hook an amp up to it. it will blow. it is an 8ohm sub. i have yet to run across and 8ohm amp. but its not raded to that much. i poped mine with only 25watts. just get the pioneer slim thing and an amp hooked up to the line that is hooked up th the factory line. (I am 90% sure you do not need to mod the stock box with this sub) http://abcwarehouse.com/product_cata...~prod_ID~20006
Old Mar 29, 2007 | 07:42 AM
EmperorJJ1's Avatar
how much bass are you looking for? you may be well within range to get enough bass out of a stock like system... on a scale of 1-10 how loud do you think the stock sub is? and on that same scale of 1-10 (if you voted 1 then a 2 would mean double the output ect) what would ideal bass be?
Originally Posted by Shermen
no you can not hood an amp up to it. it will blow. it is an 8ohm sub. i have yet to run across and 8ohm amp. but its not raded to that much. i poped mine with only 25watts. just get the pioneer slim thing and an amp hooked up to the line that is hooked up th the factory line. (I am 90% sure you do not need to mod the stock box with this sub) http://abcwarehouse.com/product_cata...~prod_ID~20006
No its not a 8 ohm sub its a 2 ohm dvc... and i really doubt 25 CLEAN watts would blow it considering the stock amp is a 6 channel 238w (or something like that) so its using at least 79.33333333 watts
Last edited by EmperorJJ1; Mar 29, 2007 at 07:47 AM. Reason: had to specify a lil bit
Old Mar 29, 2007 | 08:03 AM
Shermen's Avatar
allright bud whatever you say. i know because i poped mine, and mine says 8ohm on the dam thing.
Shermen
Old Mar 29, 2007 | 08:38 AM
braddddddd991's Avatar
the stock sub is pointless
im getting two 12 inch kicker solo and all new speakers =]
Old Mar 29, 2007 | 08:52 AM
EmperorJJ1's Avatar
http://www.pioneerelectronics.com/chevy/index.html
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
c_m_shooter
Sep 27, 2015 04:40 PM
