popping noise on high volumes
ever since i installed my 4ch amp ive been having nothing but problems, the newest problem is whenever the volume is turned up i hear a popping noise every once and a while, it only lasts for a split second but on some songs it happens more than others...
could this be because i ripped like 90% of my songs off youtube (burned at 4x speed tho for sq purposes) ive also thought maybe the ground was popping out or whatnot but this only happens when the car is running. any help appericated |
probably the music. youtube sucks for quality. um whats the high pass filter set at on the HU and or amp?
how high are the gains set on the amp and are the pass filters set on hpf, lpf or full
low pass on the 4ch amp...i have the option of HPF or LPF on the HU but lpf on the amp pretty much cuts out all the bass...
and emp i guess you didnt get my pm i sent a few days ago? maybe ur box was full... but anyways i put my btl in my friend car with a 800rms amp and mmmmmm so so sweet, made my ears pop at looow volumes |
popping noise
i installed my mono amp and im having the exact same problem. i have re run all of wireing like 10 different times and ways and nothing seems to work. im using a line out converter for my rca cables. i was just wonderin how to fix it i have tried prettty much anything possible..
lol im sure your excited T2k is on the way man...
um the 4 channel should be on high pass not low pass low pass is for the sub only hesty problem is the LOC.. have u tried unplugging the speakers ur using for signal too see if thats the issue? |
(Post 4322067)
low pass cuts out the highs high pass cuts out the bass. either ur wrong and have them swapped in ur mind or thats probably the issue
ya another retard mistake on my part cuz its pretty easy to remember
low pass = low notes pass through high pass = high notes pass through :thumbsdow:thumbsdow:thumbsdow |
