Problem with power inverter.
Old Jan 20, 2007 | 08:46 PM
Badmunky's Avatar
Ok my fiend has a 1500 watt power inverter in his semi.
The truck has a good alt and 4 new batteries in it. There big batteries so there not the problem.
The problem is that his inverters keep dieing. He is puting a 600-1100 watt load on the thing 1-2 times a day for 5-8 min and its rated for that.
Im wondering if the power wire he used has to high a resistence and that is the problem.
One thing to note is that the invert keeps over heating. And we done know why.
It is wired right and and works fine but they die in like 2 weeks time.
There Cobra inverters and he has killed 3 so far.
His wife has the same inverter and uses it the same way (To cook food) and its wired the same way as his and hers has lasted almost a year now.
The only differance is that he has a freightliner and she has a volvo. Thats it.
His alt is showing 14.3 volts all the time and was just replaced last week.
Any Ideas as to why this might be happening?
Thanks.
Old Jan 20, 2007 | 08:50 PM
diablo2007's Avatar
it must be bad tell him to return it cause i have the same one and it wouldny even power a 15" tv without dying, exchanged it now it works
Old Jan 20, 2007 | 09:36 PM
Badmunky's Avatar
He has exchanged it 3 times now. But they keep dieing. We wont to know why its dieing.
Later
Old Jan 20, 2007 | 09:47 PM
diablo2007's Avatar
damn im not sure then how long are the power wires? if their long id try to get it within a foot of the batt just so that you know everything is copestetic
Old Jan 20, 2007 | 10:06 PM
Badmunky's Avatar
There 8' long 2gauge wire with a 150 amp braker on it. There is no way to get the wires any shorted do to the location of that batteries and the location where you have to mount the inverter.
WE are going to check everything out tomarrow agen and see if we can find a problem. Its to dark and cold out side right now.
Later
Old Jan 20, 2007 | 10:08 PM
diablo2007's Avatar
well it really doesnt sound like there should be a problem, but good luck
Old Jan 20, 2007 | 10:17 PM
Badmunky's Avatar
I know. But there is. Sins it keeps killing inverters.
One more thing. He has a frezer hooked to it that pulls a 5-10watts all the time and puts a 300 watt load on it from time to time when it runs.
Later
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
