PS2 work with this headunit?
heres the back of the headunit:
now I know you cant just plug the A/V cords in the back, what Im wondering is if there is any cord converters to fit in the back.
Thanks for the help.
The Blue plug connection should be for the power/speaker/remote/ect wires
One of the white plugs should be Audio/Video in and the other should be Audio/Video out.
The yellow one I'm guessing is to hook up a aux device (changer/expansion module)
I think the black one is a S-video that is used for back up cams.
Without knowing the model or brand this is all just a guess based on what mine was like.
The unit will come with dongles of cables that will plug into the plugs on the back, on those dongles will be RCA cables and whatever other functions come with the unit.
You will still have to buy the wire adapter to get it to adapt to your car, theres info in the sticky at the top of the section on what adapter your car will need depending on the year/model.
Plus your going to need a Metra 95-3302 for the dash trim kit
Thank You
To the OP- I guess I didn't really answer your question, so Yes you can hook a PS2 up to that HU, as long as you have a 12 to 120 volt converter thats powerfull enough to run the PS2. And if you get one of the ones that can be hardwired rather than plug into a 12v socket, don't hard wire it to the battery, or it will never turn off. (oh yeah and make sure you put a fuse on it no matter where you hook it up to)
So are you going tell us what brand the unit is?
