Question About Install....
Old Mar 15, 2008 | 02:04 AM
Raven SS's Avatar
so with my clarion max675vd going in I had one question....my harness has a ground wire and the harness from the deck has a ground wire...do i attached them or do i ground them to the same part of the car? and of course the other question would be about the ebrake wire do i ground that to the same source or to a different spot? thanks in advance...
no one can help?
Old Mar 15, 2008 | 02:08 AM
WhiteSSBalt's Avatar
Not a Sebring
I cant really help........
But I dig the sweet pink car in the background.
And whats funny........im an audio/video installer in the US Capitol, lol. But I don't mess with car stereos. Only commercial jazz.
blu3_v1p3r's Avatar
well I would think that they would get connected, and not grounded. The wires coming from the deck are all one group, and get connected to the harness. The other peice that harness clips into should have a ground wire that is already grounded.
Old Mar 15, 2008 | 02:11 AM
beercan's Avatar
The two ground wires coming from the deck and the harness need to be grounded, doesnt matter if they are together or not, but personally im running the same head unit and i tied the two together and grounded them. Now with the parking brake lead, all you have to do is simply ground it with the harness wires and you have it. So basically all you need to do is tie all three together and put them on a chassis ground.
Old Mar 15, 2008 | 02:16 AM
ssmokin's Avatar
no one can help?
no no no...all these guys are WRONG! the first thing you need to do is PICK UP ALL THOSE TOYS BEFORE YOUR WIFE GETS HOME!
Old Mar 15, 2008 | 02:21 AM
blu3_v1p3r's Avatar
well they guy that said all three need ot be grounded is wrong... yes the deck need to be grounded... you can ground it your self... and that will be it or you can connect it to the harness that clips in to the stock harness peice, and i will be grounded already... the stock harness has a ground in it... and with the e-brake i'm not to sure what your asking... and yes those toys need to be picked up... before the wife get home... lol
Old Mar 15, 2008 | 02:26 AM
mikey13's Avatar
You connect the wires together. The ground from the harness is already grounded, so you just need to connect the ground from the deck harness to it. I'm not sure about the clarion but on the pioneers I just use a t tap and tap into the e brake wire to the ground wire.
Old Mar 15, 2008 | 02:36 AM
beercan's Avatar
I think the statement in bold says enough. Raven trust what I said and do it, all shall work
Old Mar 15, 2008 | 02:39 AM
EmperorJJ1's Avatar
just connect the 2 together... cut off that awful connecter thing on the aftermarket HU ground side... To get the ebrake to work its going to take some trial. Strip it some and put it in a ground location (either the HU and harness ground if you havent connected them via crimp cap or other insulated connector or shove it in the actual ignition where ur key goes) If you get video then cut the wire short and connect those 2 grounds and the ebrake and ur done. If not you will need to put a switch on that wire.... get one with only 2 leads and connect one to the ebrake wire and the second to a ground.
Old Mar 15, 2008 | 02:40 AM
denlou's Avatar
You connect the two. Both units are grounded, but by connecting the two you ensure there's a clean ground for the signals to work off of.
Old Mar 15, 2008 | 02:42 AM
EmperorJJ1's Avatar
a chassis ground isnt required on the cobalt. The reason they have the ground wire on the harness is so you can connect along with the ground on the HU and be done with it. A chassis ground on every car would be very annoying but since some dont have it all hus have the funky spade terminal thing
Old Mar 15, 2008 | 04:41 AM
Raven SS's Avatar
thanks everyone for input...and for the harness that goes to the car it came with a power wire...i run that from the HU power wire to like the windshield wiper fuse?
and beerman u have pics of the HU installed? dou like it?
Old Mar 15, 2008 | 04:42 AM
Mnatvyc1223's Avatar
why the **** didnt u ask me???
Old Mar 15, 2008 | 04:44 AM
Raven SS's Avatar
if u would respond to my text ************ dont get me god damn started
Old Mar 15, 2008 | 04:46 AM
i could have come over and answered all ur questions! what part about GSE dont you understand???
<------EEEEEEEEEEEE-lectrician...
Old Mar 15, 2008 | 04:47 AM
Raven SS's Avatar
lol well when my cobalt gets back u can install all my **** then bitch....
Old Mar 15, 2008 | 04:48 AM
yea, and this guy will get free tuning for life
Old Mar 15, 2008 | 04:50 AM
Raven SS's Avatar
lawl...i'll install it myself...
Old Mar 15, 2008 | 04:51 AM
u should relax
Old Mar 15, 2008 | 04:56 AM
Raven SS's Avatar
i am relaxed...a vicadin and 2 32oz king cobras got me there
Old Mar 15, 2008 | 05:02 AM
thatsbad for u
Old Mar 15, 2008 | 05:03 AM
Raven SS's Avatar
so is breathing....and walking is bad on my back..gonna die sometime mid as well be from something worth dieing from
Old Mar 15, 2008 | 05:47 AM
EmperorJJ1's Avatar
yes or sunroof fuse
Old Mar 15, 2008 | 10:26 AM
blu3_v1p3r's Avatar
yes the wiper fuse, or suroof fuse, will work, or you can add a fuse for it...
Old Mar 15, 2008 | 01:07 PM
Raven SS's Avatar
would it be better if i add a fuse...i dont have a sunroof
