question about using fuses
when i install my headunit i'm going to put a inline fuse on the accessory wire when i hook it up to the windshield wiper fuse. i'm also going to put a fuse on the remote wire going from my headunit to the amp.. i'm going to use a 10A fuse for both of these.. is this a good idea to do this?
the other slots for fuses have no power going through them at all.. the only ones with power are the ones being used from what i have been told. could i just run the turn on wire for my amp from the battery and just put a switch on it?
really i didn't know they had fuses that low... are they normal fuses that are used in cars? the right side is the proper side for placing the fuse tap correctt? if i run the wire for the amp off of the right side of the fuse i won't need a inline fuse on that wire will i? does the amp turn on wire draw a lot of power?
