Rear speakers and Subs not working
the other day i realized that my subs were no longer working. i have 2 10's and the stock factory 8 in sub. i thought it was something with the wiring so i checked all that out and its all wired corretly. then i noticed that the rear speakers arent working either. my aftermarket amp and subs are connected from the rear speakers. they are tapped into the wire to get the signal. can someone lead me to the right direction on how to fix this problem and get the rear speakers and all 3 subs working again?
How do you figure?
If everything is running of the rears, and its faded forward then no they wouldn't be working.
I take it you have an LOC
Go in your trunk and take a look where your LOC is hooked up to the rear speakers, make sure there is a good solid connection.
Everything is tied in to the rear speaker line, even the stock 10" sub, if the LOC is still firmly connected then maybe disconnect it and hook the stock speakers back up without it, if the problem is still there it might be a problem with the stock amp, if it fixes it self then the problem lies somewhere in or around the LOC
