Remote start question??
Old Nov 4, 2012 | 01:57 AM
Geo_SS's Avatar
I have everything connected have the xk09 updated and and viper module 4704 2 way remote and unlock, lock, trunk everything works.. Only thing is, is that the car wont turn on, i have the ignition power but it wont crank. Any help guys?? im almost done with it just this issue.
Old Nov 4, 2012 | 06:19 PM
blueLNFftw's Avatar
passlock
Old Nov 4, 2012 | 06:28 PM
BlackLsCoupe's Avatar
is it a manual trans? cause i had same issue you need to bypass the clutch switch
Old Nov 4, 2012 | 06:38 PM
MastaShaKe_88's Avatar
^^this
Old Nov 5, 2012 | 02:02 AM
Geo_SS's Avatar
yeah its manual. how would i do that?
Old Nov 8, 2012 | 12:21 AM
VancouverTurbo's Avatar
You dont need to bypass the clutch. You need to set it to reservation mode. Look in the manual it has steps on how to do it.
Old Nov 8, 2012 | 09:37 AM
sLAsh's Avatar
For mine to work you have to have foot on brake and clutch. Put tranny into neutral. Release clutch FIRSt, then brake. Car continues to run when you remove key. Shuts off engine and locks door after you close it.
Other remote starters may use different sequences to ensure car can't be remote started in gear so RTFM.
Old Nov 8, 2012 | 09:53 AM
kikal8's Avatar
With the viper starters the sequence is. Hold the brake. Pull the ebrake up. Take ur foot off the brake. Push the renote start button on the key fob. Wait for the headlights to stop flashing. And take the key out. That easy. The car should keep running.
I doubt his issue is not being able to get it set.
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
