Reverse Lights not working?
Old Oct 13, 2013 | 04:26 PM
JBAG's Avatar
For some reason the lights on my trunk aren't working. Including my reverse lights of course. I really wouldn't care about it but I need them to work to pass safety. I took the bulb out and its not burnt out. What could the problem be? Reverse light switch? Fuse?
Thanks in advance!
Old Oct 13, 2013 | 04:28 PM
royce777's Avatar
check fuse first, if not fuse there has to be a loose connection. I had a similar problem
Old Oct 14, 2013 | 03:48 AM
EmperorJJ1's Avatar
check for a loose connection/ pinched wire ect, check fuses and if nothing then try replacing the reverse light switch. very unlikely the 3rd brake and reverse would just so happen to go out at the same time and not be connected
Old Oct 14, 2013 | 03:59 AM
andrewcarr1993's Avatar
I was going to say the reverse light switch but that wouldn't be all the taillights.
Old Oct 14, 2013 | 07:36 AM
JapEatr's Avatar
South Central *********
Common issue with the harness behind the trunk lid carpet, repair replace harness
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
