so i got my subs
so i got my subs
i get my subs, 2 kicker cvr10s, they are 250rms each, 500 peak
to save money im gunna run a line out converter
this will allow me to get a better amp also, which is my next question
im looking at this one:
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
any opinions?
or should i go with this:
http://cgi.ebay.com/KICKER-ZX550-2-C...1%7C240%3A1318
bump......
25 views come on.... bump
any opinions?
bump......
Last edited by nikebaseballx00; 12-02-2008 at 07:25 PM. Reason: Automerged Doublepost
the second one is going to be your best bet for the combo you want, the dual channel amp will deliver enough rms to each sub with out over powering the subs, the first amp would be to weak for the 2 subs but it would work if you had to
oh and what impedance is the subs?
cause the second amp would be your best bet cause it is dual channel and will deliver close to rms for each sub, depending on the resistance of the coils, that will determine how much power the amp will put out and depending on how you wire the subs(series or parallel) you can alter how the amp views you subs resistance
u could get a mono amp........and run them ontop of each other........cuts the impedence in half and that will bump.........im in the middle of doing my system.......i went wit a 12 inch bazooka tube and running a 400 watt amp to it.....and a 4 channel 400 watt amp to my new speakers.........and dont forget to dynamat!!!
im on a tight budget like under 300 haha
i have the free subs, so i just need to get an amp, wiring and im gunna make my own boxes
Last edited by nikebaseballx00; 12-02-2008 at 09:09 PM. Reason: Automerged Doublepost
do yourself a favor.......save up your money and do it right and do it once.........ur 16 so u got plently of time...........im 18 bro and i finally have the money to play around with but it takes hard work and taking those extra hours when the boss offers......just my 2 cents good luck wit the sub install.......and if ur doing a LOC i suggest MTX RE-Q
I had two comp VR's in my mustang, and ran a KX750 amp, and had the gain turned way down. I have a KX450 amp in my balt, and run two equally mtx subs and it pushes them just fine. You can save you some money there and still get the same quality.
yea, thats later down the road
although every kid at school with subs doesnt have dynomat and they sound alrite, just a few rattles here and there
one kid has 2 kicker l7s, 12" squares running a hifonics brutus to them, **** pounds lol
i know not to aim the subs at each other either so im gunna angle them forward
Last edited by nikebaseballx00; 12-02-2008 at 09:24 PM. Reason: Automerged Doublepost
my comp vr's were the same as what you had, in the kicker ported box. my new subs are mtx 5500 series 12's. they are 400 watts rms a piece, but my 450 pushes them fine. Unless your going to max them out ALL the time, I think you can get by with a 450 watt amp. Plus with a smaller amp you definately won't have to use a power cap. You should check out www.ikesound.com for some reeally good deals on stereo stuff, I live by this website, and would suggest it to anyone looking to buy stereo equipment. They have REALLY cheap wiring kits too.
i found a good amp on that site that would work either at 2 or 4ohms perfect, at 2ohms it puts out 280rms and at 4ohms it puts out 220rms
i just found it at sonicelectronix for like $10 more, but im gunna buy my wiring and LOC from there too so it will save me in the long run
http://www.sonicelectronix.com/viewi...mpaign=froogle
how much do u think it would cost to make 2 small subwoofer pods for each corner? if i did it in the back of the trunk i would use fiberglass, if i did it in the front of the trunk agains the seats, i would make a triangle like box for each side so i can fit my snowboard in
I don't know anything about boxes. I would go with ported boxes. thats what kicker went with for their boxes, even though I know alot of people live by sealed boxes. Sealed boxs hit harder, but you get better sound quality out of a ported box, IMO.
right... i only use 1 channel/mono block amps with subs.. and it definitely pays off
agreed.. plus kickers produce a high amount of air.. it's like these things are made for ported boxes lol
i placed my order:
boxes= http://www.sonicelectronix.com/item_...+-10SQTC-.html
amp= http://www.sonicelectronix.com/item_...MF-1250-2.html
wiring= http://www.sonicelectronix.com/item_...+NTX-5570.html
LOC= http://www.sonicelectronix.com/item_...Converter.html
dont bitch about my wiring, if its really shitty i have extra stuff at home, just wasnt sure if it would be enough so i bought some extra stuff that was cheap with good reviews...
all should be here in a week or 2
