Sound System
Old Apr 21, 2013 | 07:50 AM
duffman11's Avatar
Sound System
I've helped install a few radios and Speakers before. Nothing has ever taken me 3 days to finish. Dont ever ever ever ever ever touch your sound system in a cobalt SS. Leave it alone.
The End....
Old Apr 21, 2013 | 01:06 PM
tru2nrtt777's Avatar
Wow, I have done several audio builds in cobalts and never taken 3 days for a simple install.
Old Apr 21, 2013 | 01:18 PM
xriverrat's Avatar
Please tell
Old Apr 21, 2013 | 01:31 PM
TommyP's Avatar
AWD > FWD
Are you nuts? Having the battery in the trunk makes it really easy
Old Apr 21, 2013 | 02:18 PM
BPacak's Avatar
Vtec Rep
yeah you need to explain
Old Apr 21, 2013 | 03:36 PM
duffman11's Avatar
OKay well I ordered everything off CrutchField minus the sub I got it from Sonicelectronix.
NVX NSW102 - Sub
Pioneer AVH-P8400BH- Radio
Polk Audio DXi650s 6.5"- Rear Speakers
Rockford Fosgate Prime R1675-S 6.75" Component Speakers - Front Speakers
Alpine MRV-F450 - 5 channel powering everything
This whole build has been arround retaining the stock look.
We pop out the old sub and slide in the new one. As expected it didn't fit. Even though we were told it would. So we spent 4 hours taking the box apart and fabricating it to fit the sub.
Rear speakers. Install went clean with the brackets but the rear "apillars" didn't want to go back on so easily. Spent 30-45 min ******* with them.
There is no amp bypass kit for this car. Instead of us spending forever how to bypass the amp we decided to just run new wiring. We got the door panels off and took the front speakers out. The components did not have a bracket to "fit" into the stock spots so we had to fabricate 2 out of plastic. We weren't sure about making new brackets so we reused the stock ones. The Screws were to long and had to dremel them down. Then the door didn't want to go back on.
We went to wire the Radio up and are now trying to decipher which one of the harnesses we need to use and where to heat shrink the wires together. Nothing has gone in the way it should have. We have had to modify everything in the car.
It's just a big pain in the ass to keep it looking stock with aftermarket stuff that is claimed to "fit"....
Old Apr 22, 2013 | 03:25 AM
EmperorJJ1's Avatar
lol shoulda sent me a PM i could have told u that sub wasnt going to fit. what screws are u talking about for the front door speakers? if u utilized the stock mounts there shouldnt have been an issue with the doors not fitting
Old Apr 22, 2013 | 05:00 AM
duffman11's Avatar
Radio still isn't wired up -_- aughghg
Old Apr 22, 2013 | 05:21 AM
EmperorJJ1's Avatar
lemmie know if u have any questions
Old Apr 22, 2013 | 11:47 AM
duffman11's Avatar
Seems like we have everything finally figured out. I wish GM would have made that Amp better. They set this sound system up in the most annoying way possible.
Old Apr 22, 2013 | 01:44 PM
EmperorJJ1's Avatar
ya its pretty bad but then again not really could have been worse
Old Apr 22, 2013 | 04:08 PM
duffman11's Avatar
****, We have to use the ******* stock amp....**** this ******* bullshit. I ******* hate this car sooo much. I've never installed anything with ease. Not even god damn lowering spring. Spun every ******* bolt. **** modifying this POS car anymore.
Old Apr 22, 2013 | 07:22 PM
duffman11's Avatar
******* sucks, install an Aftermarket system and you can't keep your steering wheel controls. and have an aftermarket amp.
Old Apr 22, 2013 | 07:57 PM
Drunkship's Avatar
You can buy a wiring harness to keep your steering wheel controls.
Old Apr 22, 2013 | 08:01 PM
duffman11's Avatar
I did....
Sunburst_SS's Avatar
I installed door and rear deck speakers, and a touch screen pioneer.....it wasn't bad at all, took like half a day. Also, you can get an adapter harness to keep your steering wheel controls.
Old Apr 22, 2013 | 08:39 PM
duffman11's Avatar
Did you install new speaker wires. We didn't use the ones that were hooked up to the Stock speaker. We ran all new wiring. I also installed an aftermarket 5 channel amp.
Old Apr 23, 2013 | 01:34 AM
EmperorJJ1's Avatar
what year car is it?
steering wheel controls are unaffected by the stock amp
Old Apr 23, 2013 | 04:06 AM
duffman11's Avatar
08...I'm just going to take it to a professional. I'll pay the 300$ to have everything done right. Aughgh.
The guys we called from the PAC harness said you have to use the Factory Amp to get the wiring harness to work....I thought it was BS but my buddy who is wiring up seems to think they are right.
Old Apr 23, 2013 | 05:07 AM
EmperorJJ1's Avatar
to get the steering wheel controls to work?
in an 08 the chimes are produced by the radio. so if u get a module harness u have to utilize the factory amp for chimes unless you wire in a separate speaker for just the chimes. mind you this is only for the sound and by no means does the factory amp do or control anything other than the reproducing the chime sound
Old Apr 23, 2013 | 05:09 AM
duffman11's Avatar
I don't care about the door chiming if I leave the key in. I've never locked my keys in my car. (knocks on wood) I just want to be able to use cruise control and change the radio station from the the steering wheel.
Old Apr 23, 2013 | 05:15 AM
EmperorJJ1's Avatar
cruise control works regardless of radio situation. steering wheel controls work without the amp but need to be wired properly
where are u at now? sorry this thread is all over the place. is the radio installed? does it turn on? does it play? what if anything isnt working with the radio?
what steering wheel control interface did you get? brand and model?
Old Apr 23, 2013 | 05:20 AM
duffman11's Avatar
I don't know, I have to have my car now. I need it for work. My buddy put something back together. I don't know what he's done. I don't want to deal with it. It's been to much of a headache, I'm plenty pissed to think paying someone $500 is a good deal right now.
Metra ASWC Auto Sensing Steering Wheel Cntrl Intrfc
and
GM OnstarGMOS-LAN-04 LAN Data Bus Interface
Old Apr 24, 2013 | 12:01 AM
duffman11's Avatar
Going to have the car done by a shop on Thursday. Quoted $800....Yay -_-
Old Apr 24, 2013 | 12:18 AM
Wow, go to another shop. You have a simple install, not a ton of custom ****.
