Speaker Baffle
Old Dec 4, 2010 | 07:46 PM
mastersource's Avatar
Speaker Baffle
I had to get new speakers for my 2005 lt because the front 2 died for no reason. I got Alpine SPR-17C and installed foam baffles also. Does anyone have any experience with the baffles on should I keep them or not. I live in Michigan and it is snowing here a lot so I at least want to keep them on during the winter just in case my seal is leaking a little in my window. Thx for all your input.
Old Dec 5, 2010 | 07:19 AM
EmperorJJ1's Avatar
just install them and see what happens if it sounds ok then leave it and done
Old Dec 8, 2010 | 08:36 PM
SS SCHGD's Avatar
I have some installed, sounds fine, but I still lost another speaker...I am going to rerun all my wires this winter, and if I loose another speaker I'll end up buying some Marine grade ones.
Old Dec 8, 2010 | 10:18 PM
EmperorJJ1's Avatar
pics of the broken speaker?
Old Dec 12, 2010 | 12:03 PM
Did you cut your baffle at all or just leave it and have a small hole for the wires?
Old Dec 13, 2010 | 07:32 PM
SS SCHGD's Avatar
small whole for the wire, and as for pictures, nothing to see, it's just a speaker....(with rusty metal on the back and won't give me a solid "4ohm" resitance (or 6 or 2 or whatever it should be, jumps from .2-12 or so)
Old Dec 14, 2010 | 12:23 AM
EmperorJJ1's Avatar
does the coil look copper still or no? if the coil looks water damaged and its already number 2 then u know whats going to happen to number 3 id just go straight into marine
Old Dec 14, 2010 | 12:24 AM
Cefaln452's Avatar
foam baffles take away from the sound of the speaker... get rid of them
Old Dec 14, 2010 | 12:26 AM
Cefaln452's Avatar
if anything make a splash shield out of abs of lexan if you are truly worried about it, but if your getting that much water in your door, you have a problem.
also if anything, take some sound-deadener and make a cup around your speaker.
Old Dec 15, 2010 | 07:51 PM
SS SCHGD's Avatar
it's a plastic baffle, and I have been trying different things each time. If I try a 3rd pair thats not marine, then they will be sealed from behind. the first set was rusted on the back (coil) I'll also be checking the wiring.
DANRICKARD
Oct 1, 2015 12:08 AM
xxenjoi11
Sep 29, 2015 12:36 PM
brickloaf
Sep 25, 2015 09:10 PM
dieGone
Sep 23, 2015 10:20 AM
