Stock Pioneer Sub replacement
Old 05-16-2007, 11:26 AM
celicacobalt's Avatar
I'm not gonna do this anytime soon but if or when my stock sub blows i was thinking how much i like the stock setup. What kind of Pioneer sub would be a direct replacement to fit in the stock location that would be an upgrade? Can it be done on the stock amp or would I need to piggyback an aftermarket amp?
Old 05-16-2007, 01:03 PM
effex80's Avatar
i love how you know your going to blow your sub. lol
Old 05-16-2007, 03:33 PM
yeah i play it loud all the time. so has anyone done anything like this?
Old 05-17-2007, 10:23 AM
cobi's Avatar
uhhhhh your not going to blow that sub with the factory amp even if its loud all the time. it doesnt have much power going to it at all as it stands.
Old 05-22-2007, 12:52 PM
xtremeGM's Avatar
I found that most of the pioneer subs that are sold in the stores were a little to deep to work in the stock box. I went with an infinity powered by a kenwood amp because the stock amp just isn't strong enough.
Old 05-22-2007, 04:56 PM
Johnboy12358's Avatar
I found this thing, dont have any idea how it would work though. I know you would need a beefier amp for it
http://www.crutchfield.com/S-b49eRrs...130TSS2541#Tab
I also wonder how big the stock box is, if it could even accommodate anything else than what comes from the factory (or if it would even be worth it to reuse that box)
Old 05-22-2007, 10:11 PM
Rodimus_Prime's Avatar
I blew mine up , lasted less than a week on 200rms off my kicker zx400.1 i dont care though im replacing it with the mentioned pioneer
Old 05-22-2007, 10:37 PM
You need to update on how that woofer works out...
Are you using the stock enclosure?
Old 05-22-2007, 10:45 PM
Dj_BuCa's Avatar
ya, it'll be tough to blow the sub with the stock amp in there. if anything, you might have the spyder seperate on you from over excursion. An upgrade would be building your own enclosure in the corner. the enclosure for that pioneer sub is already to small, and any greater of a sub will under perfom in that small lil plastic box.
Old 05-23-2007, 12:36 AM
RBC
RBC's Avatar
Someone should make a bigger box to mount in the stock location, and maybe make it look somewhat like the stock enclosure if possible.
Old 05-23-2007, 09:04 AM
Im using the stock enclosure with the new pioneer specs say it will work in down to a 0.3 cu ft box, anyone have any idea what the volume is of the stock enclosure?
Old 05-23-2007, 09:08 AM
OrngBalt's Avatar
I agree... but for both sides. I think it would be a unique look to have a sub on either side of the trunk. I tried to find such a thing but just couldn't
Old 05-23-2007, 03:25 PM
lightsout's Avatar
I think as someone pointed out in another post, it wouldn't work well if you had another sub on the other side of the trunk. With both subs facing each other the sound waves would bounce off of each other and it wouldn't sound good at all.
Like it's been mentioned already, the stalk amp does not have enough power to blow the sub. Plus, the sub is not even powered directly from the amp, it's bridged off of the rear 6/9's.
If you want more thump from your sub than you should add a second amp that will power only your sub. You may not even need to change your stalk sub then. Also the advantage of adding a second amp to power only your sub is if you have an after market deck with a sub controller, you can connect your sub to this.
Old 05-23-2007, 03:51 PM
ptrblkz24's Avatar
Acording to pioneer,the stock box is 18 liters.I tried converting it to cubic feet and it came out to be 0.64.Anyone wanna verify if thats right?Im looking for a replacement sub that will work with the stock enclosure also.I have a box with 2 12's in it,but i dont wanna put it in casue it takes up the whole trunk.
Heres where i got my information from:http://www.pioneerelectronics.com/chevy/index.html
Old 05-23-2007, 05:16 PM
well the shallow pioneer is for 0.3 to 0.8 so that should be perfect
Old 05-23-2007, 08:19 PM
Dj_BuCa's Avatar
i'm going to be installing a second sub in my trunk. my buddy is selling me his out of his old balt. i'm gonna try and mount it in the other corner and run dual tens off a memphis amp i have kickin around with sub control.
Old 05-23-2007, 09:34 PM
18 liters ~ .636 cu.ft. so yeah
http://www.google.com/search?hl=en&s...ft&btnG=Search
If someone uses this sub, I seriously want to know how it turns out. I would definitely do this if it sounded good
....Hell I may have to guinea pig this if money falls right over the next couple of months
Last edited by Johnboy12358; 05-23-2007 at 09:34 PM. Reason: Automerged Doublepost
Old 05-25-2007, 12:13 AM
ptrblkz24's Avatar
I heard that pioneer subs arent that great.The guy at the stereo shop by me recommende the jl 10w1v2.The enclosure specs are dead on with our boxes,and there pretty shallow too.In my oppinion,you cant go wrong with jl.Plenty of my friends have them in there cars and they slam.
Heres the link:http://mobile.jlaudio.com/products_s...p?series_id=15
Old 05-25-2007, 12:35 AM
lower power handling and they are too tall
Old 05-25-2007, 01:53 AM
ptrblkz24's Avatar
Yeah,they do have a lower power rating,but i think they will still sound decent.But i dont think there too tall.I have the stock sub sitting next to me and the depth is 4 1/8".The jl sub is 4.34".With alittle modification it should fit with no problem.I dont know if the pioneer sub mentioned above will be a direct fit either.The stock sub is 10.5" in diameter.The pioneer sub above is 11.1" in diameter.So no matter which sub you choose,i think ur gonna have to trim the box to make it fit.I bought the empty box to the stereo shop,but he didnt have any jl's in stock so i can test fit it.Im gonna try and go to a different shop tommorow and see if they have any of the subs mentioned above and see if they fit.
Old 05-27-2007, 09:45 PM
FuriouS's Avatar
Can someone post some more information if you have done this replacement?
What sub? model? Pics?
Where did you get your input for the replacement amp? did you just take the speaker lines for the rear sub and amplify it?
I would like to put a 400w mono amp with an infinity 10" sub
Old 05-30-2007, 01:33 AM
DARIN616's Avatar
i just realized that cobalts would look good as cop cars, sorry off topic
Old 05-30-2007, 01:41 AM
clint06ss2.4L's Avatar
Pioneer has a new sub that is very thin and will fit in the stock box, and will take minium power to run it and will sound great.
Old 05-30-2007, 08:58 AM
yea thats the one already mentioned in this thread, i dont have it yet but should very soon
Old 05-30-2007, 09:15 AM
You're installing the new thin pioneer in the stock enclosure? I'm very interested to find out how that sounds.
Quick Reply: Stock Pioneer Sub replacement
