Stock Sub Replaced with Polk MM1040
Old 02-26-2012, 07:56 PM
JSSpedale's Avatar
I am currently in the process of replacing the stock sub with a Polk MM1040. I am taking pictures along the way for everyone to see I am also using the "How to" thread about this to help out. So far I have done/will have to do a few things differently.
For the hole on the back I plugged with a 1/2" plug and used caulk to seal it.
The sub itself does not fit. It hits the bottom of the box and has about 1/4" to go and the bolt pattern is different, therefore I am in the process of finding a 3/4" MDF Ring to space it out.
I'll be updating as I go
Old 02-26-2012, 08:00 PM
Blowncavy's Avatar
Whats the box space requirements on the polk?
I would just get an small ported single 10inch speaker box myself
Old 02-26-2012, 08:08 PM
JAYNO20's Avatar
is that Polk audio sub the same size as the stock sub?
ei3dag3's Avatar
Interesting. Let us know where you'll get that spacer and what amp you're using.
Old 02-26-2012, 08:38 PM
JSSpedale's Avatar
It's a 10" sub, and it would fit in the box if it was a 1/2" inch shorter. The magnet hits the back of the box.
The optimal sealed box size should be 0.66 cu/ft and the stock box is 0.6 cu/ft.
I will be using an Alpine MRX-X50 amp.
Old 02-27-2012, 11:11 PM
JSSpedale's Avatar
The amp and wiring kit came today! Started on the wiring today since I am waiting for a 3/4" MDF ring to mount the sub. Tomorrow I will install the amp in my car and run all the wires.
Old 02-27-2012, 11:16 PM
toysareforboys's Avatar
Looks great so far!! If you can't find that MDF ring slap her in there inverted till one shows up
-Jamie M.
Old 03-04-2012, 04:15 PM
JSSpedale's Avatar
All Finished!!!!!!! I ended up splitting the MDF ring I ordered online and did not want to wait any longer so I went to Home Depot and bout a slab of 3/4 MDF and made my own and went at it again. Took my a little over 3 hours to make and install the ring and sub. I have 4 screws that hold the ring to the box and a bead of silicone. The subwoofer sounds awesome! I'm going to wait a little bit but I plan on painting the sub box and ring to match my car and the Pioneer letters white. The amp does not need a remote turn on wire, it has signal sensing and it works great. There is a lot of room to make it louder but the speakers can't keep up. I would recommend this as an upgrade!
Old 03-04-2012, 05:41 PM
Originally Posted by JSSpedale
All Finished!!!!!!!
Looks great! Nice work on the ring Did you try and fit the stock Pioneer speaker grill over the new sub (to protect it when you throw junk in the trunk)? Yeah, paint that MDF ring and it'll look all factory!!
Got a good camera for some videos??!
-Jamie M.
Old 03-04-2012, 07:27 PM
JSSpedale's Avatar
I only have my phone EVO to take pictures and videos. It's a different bolt pattern for the grill that's why I didn't use it. Polk makes a grill that fits the sub I might buy that. but for now im just glad to have sound.
Old 03-05-2012, 03:38 AM
EmperorJJ1's Avatar
aww shoulda painted the ring black
Old 03-06-2012, 12:41 PM
574's Avatar
Should do a detailed how to!
Old 03-08-2012, 03:28 PM
Prestige_Worldwide's Avatar
Dammit I need someone around me that knows how to do stereo ****. I want to do this in my HHR in the worst way and I pay in high quality beer!!
Old 03-08-2012, 03:32 PM
HAHA! I have the same exact sub and amp, **** pounds!
just installed mine last week. to make it fit in the box, i just dremeled off the plug in the back of the box and then sealed it with a bunch of tape essentially. it works, completely leak free. didn't use silicone either, just the supplied gasket that came with the pold sub!
but kudos to you!
what do you have the amp adjustments set at?
Old 03-08-2012, 03:52 PM
cobaltalex's Avatar
whats the wire harness for? i wanna get this setup for my base model
(dont have the pioneer setup)
Old 03-08-2012, 07:05 PM
JSSpedale's Avatar
It's the alternative to running RCA's for your signal. The amp has speaker level inputs built into it so it takes the signal from the speakers and uses that as the signal for the sub as opposed to RCA's. I did not want to buy a line out converter and run RCA's from the head unit to the amp. It also has signal sensing to turn the amp on, so there is no remote turn on wire needed. All the wiring is in the trunk!!
LPF - 100Hz
Subsonic - 25Hz
Bass Boost - +4db
Gain - +0.5V
There is a lot of room to turn it up and the sub can handle it, but I don't like my sunroof rattling to much. It packs a lot of punch!
Old 03-08-2012, 07:26 PM
Vids man, WHERE ARE THE VIDS!?
For Mr. base cobalt guy. You can do the exact same setup as JS but instead of attaching the amp harness to the subwoofer wires, you would attach the amp harness to the two rear deck speaker wires!
Let me know if you need more help than that
-Jamie M.
Old 03-08-2012, 07:27 PM
EmperorJJ1's Avatar
sealed with tape? idk if id recommend that rice burner
Old 03-08-2012, 11:15 PM
JSSpedale's Avatar
-Jamie M.
I'm goin to visit my parents next weekend, I'll take a video with there video camera and post it up. What is it that you want to see? The sub, the vibrating rear view mirror, or how the display on the radio moves like a wave when the bass hits?
Old 03-08-2012, 11:17 PM
Sounds good, that, plus some sunroof rattle, a shot of the sub doin some work would be good too. Don't be chincy
-Jamie M.
Old 03-17-2012, 11:51 PM
JSSpedale's Avatar
Here is a link to the video I took. It is weird how the display on the radio shakes when the bass hits hard. I was hoping it would show on the video I took but it doesn't.
Also there is a very small leak I need to seal.
M2U00073.mp4 video by denspedale - Photobucket
Old 03-18-2012, 01:21 AM
EmperorJJ1's Avatar
linkin park ftw
Old 03-18-2012, 01:47 AM
I'm too JDM for you
BLAZIN07SS's Avatar
that's because it's your eyes vibrating, not the radio
Old 05-03-2012, 02:17 PM
What did you use to seal the ring to the box? Did you screw the ring into the box and then caulk it or just glue it?
Old 05-03-2012, 04:19 PM
I don't like using caulk/silicone because the fumes it gives off when drying can damage the surround on some speakers.
In this pic:
You can see I used this stuff: http://www.permatex.com/products/aut...sket_Maker.htm
And when I want it black I use this stuff: http://www.permatex.com/products/aut...sket_maker.htm
I love the Permatex stuff because it's super adhesive and never completely hardens and stays very flexible. Also easy to remove if you need to swap out the driver, etc.
-Jamie M.
Quick Reply: Stock Sub Replaced with Polk MM1040
