View Poll Results: which box would work best with 2 10" alpine type r's
sealed
21.05%
ported
13
68.42%
vented
10.53%
Voters: 19. You may not vote on this poll
which sub box
Old Oct 22, 2008 | 11:49 PM
kreid144's Avatar
which sub box
which subwoofer box would work the best for 2 10" alpine type r's
i really like this box my friend has one and he's pushing two alpine type e's sounds good
Old Oct 23, 2008 | 01:27 AM
EmperorJJ1's Avatar
ported is the same as vented... and there is no real best enclosure they all have flaws and u have to pick the one that you prefer persay. eiter way ported is generally louder then sealed anyway and built right plays low and loud
Old Oct 23, 2008 | 05:33 PM
PogoTheMonk3y's Avatar
I used to have 2 12 alpine type Rs. I had them in a prefabbed ported box. It was tuned to 38hz (Give or take, it was prefabbed). I also had them in a sealed box. Generally, you will get more quality in sealed boxes however ported boxes will be more louder. If you tune to 33-35Hz you will get a mixture between SQ and SPL. I'd pick ported anyday.
Just curious, what amp do you plan on running? I had a jl 500/1 running the 2 12s. Even below the rms, they still sounded nice.
Old Oct 23, 2008 | 06:26 PM
cobaltguy88's Avatar
depends.. its best to have a box made for the specifications and air space your subs required..
i prefer sealed though.
Old Oct 23, 2008 | 07:45 PM
kreid144's Avatar
right now i have a mitzu amp it claims 3200 watts but i doubt it i hope to get a different one before i install i will probably install the system after Christmas because i have to save to buy presents for Christmas right now but i will be picking up small pieces of the system along the way
also on another note i have read that ported is loud and sealed is clarity but vented is a mix
Old Oct 23, 2008 | 08:18 PM
EmperorJJ1's Avatar
there is no difference from vented and ported. Just 2 different words for the same thing that people will use to confuse you and make you buy something
Old Oct 23, 2008 | 08:21 PM
BPark86's Avatar
If you can fit a vented box I've always liked the sound better. Depending on how much power you are pushing a sealed box may not seem much different
Old Oct 24, 2008 | 03:54 AM
For the most part, flared ported (as you call ported) is less likely to produce port noise. If you are low on space then a flared port is the way to go. I'd rec. a slotted port tho.
Old Oct 24, 2008 | 04:09 AM
EmperorJJ1's Avatar
a properly designed box is less likely to produce port noise, shape doesnt matter
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
cw383
Sep 30, 2015 12:41 AM
c_m_shooter
Sep 27, 2015 04:40 PM
