Sub Box Sliding With Trunk Carpet
Old Jun 28, 2005 | 09:37 PM
PBiddy412's Avatar
Whats good way to stop this from happening? I just want some ideas. I was told to do velcro. Looking for other ideas...
Old Jun 28, 2005 | 10:18 PM
bredick's Avatar
on my old cavi, I used 1 1/2" angle brackets and screwed them into the box and the botom of the trunk, don't think anyone would want to put holes in a brand new Cobalt though, so it's just an idea, not really a suggestion
Old Jun 29, 2005 | 12:24 AM
PBiddy412's Avatar
Yeah it is an idea, but you are right, I don't want to drill holes!
Old Jun 29, 2005 | 12:54 AM
Darkritual's Avatar
get a heavier sub "and now for a better answer"
you can get your box resurfaced with a rougher carpet.
Old Jun 29, 2005 | 01:02 AM
DC52NV's Avatar
that velcro idea will work.
Old Jun 29, 2005 | 01:27 AM
tiny's Avatar
yeaaa, i got a Solo baric, and that slid
i use 1 90 degree angle bracket and attached it on the back of the box with a small screw
the **** if i care if i make a whole where no one will ever notice
*just make sure not to drill into anything* (gas tank)
Old Jun 29, 2005 | 07:57 AM
selfinfliction's Avatar
brackets are the way to go... brackets if done right will also deter theifs from "borrowing" your subs, you should just use a strange type of screw or bolt to fasten them in
Old Jun 29, 2005 | 08:09 AM
Dman's Avatar
plus if you use brackets with screws it counts as permenantly mounted to your car, so you insurance company has to cover it if it does get stolen...
Old Jun 29, 2005 | 03:20 PM
PBiddy412's Avatar
Thanks guys. Sounds like brackets just has more pros then cons. Did not know about the insuarance thing though...
Old Jul 12, 2005 | 01:55 AM
Kiss My SS's Avatar
i have two 90 degree brackets holding down my box in the back and two like thin hole metaly strips holding it in the front up to the croos beam in teh trunk. it doesn't move at all and i have 2 12" L7 Kickers in a 3/4 mdf box and two amps and two caps attached to teh box. so it pretty heavy.
vinny
Old Jul 26, 2005 | 11:10 AM
STLWACO's Avatar
I just put down a rubber mat the size of the trunk. NO holes.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
