Subs pulsing.... Weird... help
Old 01-06-2009, 08:55 PM
MBMCustoms's Avatar
So I have recently put in 2 12 inch Kicker comps with my old audiofonix 800w amp and a 1.5 farrad capacitor, and I also have 4 gauge power wire. So When i turn on the car or turn the key over i get this weird distortion noise and whenever i push or pull a button (like the window controls) the subs make a pulsing sound... WTH could this be???? Someone please help me.
Old 01-06-2009, 08:57 PM
I'm too JDM for you
BLAZIN07SS's Avatar
check your ground wire. where ever its grounded sand off the paint. fixed it for me
Old 01-06-2009, 09:08 PM
MBMCustoms's Avatar
i have already tried this. no good
i really want to fix this guys.
Old 01-06-2009, 09:12 PM
kkanowitz's Avatar
The only thing that comes to my mind quickly is maybe trying a ground loop isolator on the RCAs that connect to your amp.
Are you tapped into the rear speakers and have a stock deck, or do you have an aftermarket deck?
black-balt's Avatar
I have a factory head unit with a toggle switch to turn on my amp and when I leave the amp on and shut the door mine makes a loud pulsating sound too, but I kinda like it that way I won't forget to turn my amp off lol.
Old 01-06-2009, 09:22 PM
07YellowSS's Avatar
lol, i have my factory radio, with a kicker l5 and a kicker 300.1 amp. I tapped into the rear speakers and did a high level input directly through the amp INSTEAD of a line out converter. WELLLLL when i start my car the damn thing will BUZZZZ really really loud untill i let off the key. Its Scared the Sh** out of me plenty of times, it doesent do it everytime. Gets me when i least expect it .
I have pictures in my Gallery
Old 01-06-2009, 11:51 PM
EmperorJJ1's Avatar
if its a pioneer its the pico fuse. otherwise try a ground loop isolator. ur getting a ground off balance thru those rcas somehow
Old 01-07-2009, 01:50 AM
MBMCustoms's Avatar
it is the pioneer avic d-3. ^ what exact fuse are u talking about? im interested.
and i bought it at best buy and also purchased the 4 year service warranty, you think the warranty will cover it?
Old 01-07-2009, 01:52 AM
kkanowitz's Avatar
I'm not positive, but I believe this fuse is internal and surface-soldiered, so I'd try a ground loop isolator first.
Old 01-07-2009, 01:55 AM
MBMCustoms's Avatar
sorry im not too technologically inclined lol, what is this thing you speak of?
Old 01-07-2009, 10:17 PM
kkanowitz's Avatar
Something like this:
http://www.radioshack.com/product/in...ductId=2062214
Basically, if IIRC, a ground loop is a condition when the grounding of your RCAs is being interfered with electronically... So that interference prevents a clear signal to your amp, creating the noises you're hearing.
I say to do this first because its a cheap and easy way to solve it if that is even the problem, if not, it's the unit itself.
Old 01-08-2009, 12:00 AM
MBMCustoms's Avatar
thanks for the heads up. i will deffinately try this before i try to get best buy to send it in.
do you happen to know if radio shack keeps those in stock by any chance? i would much rather just go pick one up at a local store
Old 01-08-2009, 12:01 AM
kkanowitz's Avatar
That's just the first result off of google...lol. Any electronics store should have it, Circuit City, Best Buy, or your local audio shop.
Old 01-08-2009, 12:09 AM
MBMCustoms's Avatar
ok thanks. i will let you know if it works.... and if not then F***
Another Question for you though! is there any specific isolator i need to buy? or just any? let me know quick cuz i may order one online
Old 01-08-2009, 12:12 AM
kkanowitz's Avatar
All the ones I've seen are basically the same...if you can see a picture, just make sure there are two pairs of RCAs on each side. Preferably one pair should be female and the other pair male so you don't need to buy barrel couplers.
You might want to do it locally in case it doesn't solve the problem, that way you know you can get your money back easily.
Old 01-08-2009, 12:15 AM
MBMCustoms's Avatar
well i can get one for 10 bucks with free shipping and it will ship tomorrow... should i? i mean 10 bucks really isnt going to kill me lol
Old 01-08-2009, 12:16 AM
kkanowitz's Avatar
That's cool man...it wouldn't matter to me either. But I was just saying cause losing 25 cents gives some people a heart attack.
Old 01-08-2009, 12:17 AM
tony2toness/sc's Avatar
If its warranty take it to bestbuy they should fix your prob it should not do that and if you touch anything the service tech did I think the warranty is voided
Old 01-08-2009, 12:26 AM
MBMCustoms's Avatar
i just dont want to have to take it to them. they take forever and **** something up everytime they try to fix something.
Old 01-08-2009, 12:30 AM
But if they **** something up sue them lol but yea trust me if they screw something up its not your fault and you don't waste cash lol
Old 01-08-2009, 12:32 AM
MBMCustoms's Avatar
i got what you are saying. if this isolator doesnt work then i will be heading to best buy for sure cuz its almost to the point to where i want to get rid of the system.
Old 01-08-2009, 12:40 AM
BCM
BCM's Avatar
If the isolator doesn't work we could plug in my headunit and see if it still does it, just to make sure it's your headunit, or not.
Old 01-08-2009, 12:44 AM
Just make sure it doesn't look like you were messing with it lol or else your screwed
Old 01-08-2009, 12:45 AM
MBMCustoms's Avatar
ok sounds like a good idea.
will try
Old 01-08-2009, 01:09 AM
BCM
BCM's Avatar
Gotta do it before Saturday though. I'm leavin for Florida and I won't be back til next wednesday.
Quick Reply: Subs pulsing.... Weird... help
