A Switch for AEM Meth Kit
Ok, so heres the deal...
I have AEM's universal water/meth kit. It kicks on when my car reaches 7psi right now. I'm in the middle of datalogging right now for Vince. But the basic way my car is set up is without comp mode on its tuned to 22psi. With comp mode on its tuned to 25psi with meth. The thing is though, the progressive controller doesn't "know" when I'm in comp mode so soon as it sees 7psi it starts pumping meth. What I'd like to do is install a switch to turn on the controller. Now the controller has a constant 12v wire and a switched 12v wire. Which one would I put the switch on? Thank you for the help in advance guys
lookin for any input you guys have...
obviously I can't just put a switch for the power to the pump, cause the pump is in the trunk with the battery and I want a switch in the car with me
All I can think for you to do man would be to take the time to run wires for a switch in car to the power cable. Its the only way to disrupt the power to the pump to make it not work.
Yea. I was thinking about just installing a switch on either the constant 12v wire or the switched 12v wire. I just didn't know which one to do...you know?
Yea thats what I was thinking. I haven't picked out a switch yet. I could get one of those HUGE ASS ones with the cover on it like its a friggen NOSSSSSSSSSSSSSSSSS switch.
...jk......jk.....
thats the ones I like. I've used them plenty of times. Clean look, and cheap haha
but if you really want it, theres this one:
http://shop.advanceautoparts.com/web...7CGRP2020A____
hahah
hahah
hahah
However if you really wanna go fast you need the second one haha
