t10001bd at 0.5 ohms
Old May 5, 2009 | 10:16 PM
brickloaf's Avatar
soo i just realized i ordered the dual 2 ohm instead of the 4 ohm, so im gunna end up having to run my subs at 0.5 ohms (amp is stable at 0.5). my question is how much watts would it be putting out at 0.5? it does like 1500 at 1 ohm so im thinking like maybe 1750wt?
what do you guys think
Old May 5, 2009 | 10:23 PM
Bika's Avatar
Fail Less.
i think you will be able to grill steaks on that amp Invest in a cooling fan and dont have the trunk closed off. even though its stable at .5 ohm, it will still get hot as hell and heat creates distortion, and can prematurely wear the components of the amp.
cooling mods for your amp, bro.
next, make sure your sub can handle the wattage
then, get/build an enclosure that is within the manufacturer specs for that sub.
Old May 5, 2009 | 11:21 PM
brickloaf's Avatar
yea i was going to order a fan when i ordered the subs but i wasnt sure what size fan was in the 1000, ill open it up and do some measurments tonight
Old May 5, 2009 | 11:32 PM
Bika's Avatar
Fail Less.
you can never have enough cooling. Rockford amps like to run hot
Old May 6, 2009 | 12:14 AM
brickloaf's Avatar
would it run cooler if i just took the metal casing off from the top, so i could see the circut board..?
Old May 6, 2009 | 12:17 AM
EmperorJJ1's Avatar
i wouldn't recommend that. fried my T30001bd in 3 seconds low volume at .35ohm
what subs are you getting? im going to have some T1ks for cheap soon
not really but if you get anything in there that amp will fry again
Old May 6, 2009 | 12:22 AM
brickloaf's Avatar
dual 2 ohm 12' l7's
so i guess i should try to return them for the 4 ohm?
Old May 6, 2009 | 12:27 AM
Spun's Avatar
Just wire them into a 2 ohm load
Old May 6, 2009 | 12:32 AM
brickloaf's Avatar
that would only be 750rms, which is half of what it should be.
so i dont want to do that
Old May 6, 2009 | 12:38 AM
EmperorJJ1's Avatar
dual 2 ohm 12' l7's
yup depending on how much it will cost you for the swap
Old May 6, 2009 | 12:41 AM
brickloaf's Avatar
well 1 of them has already been shipped to me, and the other one is still at their factory waiting to be shipped so I emailed them asking to switch the one they still have to 4 ohm and when i get the other one in the mail if i could return it for a 4 ohm
wish me luck, im gunna need it
Old May 6, 2009 | 12:43 AM
EmperorJJ1's Avatar
gl man
Old May 6, 2009 | 07:55 AM
Cefaln452's Avatar
any of the small t power amps, can handle it... Rockford says they may get a little warmer, but they will unlikley shutoff. We were seeing how much one could take so we brigged a t600-2 at .5 ohm and pounded the **** out of it... as long as you tune it correctly you will be fine, but you are putting more strain on the amp
Old May 6, 2009 | 02:20 PM
Bika's Avatar
Fail Less.
Don't do that. the casing contains heat sinks which help dissipate heat.
Don't be a vaj. run the dual 2 ohm subs
Old May 6, 2009 | 03:01 PM
Spun's Avatar
The lower the ohm load the more stress on the cars electrical system. I think running that amp at .5 ohm would put alot more stress on the alt. If you can get the same power out of a higher final load then do so (IMO) I know its only .5 ohm difference (1ohm compared to .5ohm) but when you get into that level of draw it makes a hell of a difference
Just my 2 cents
Old May 6, 2009 | 10:06 PM
brickloaf's Avatar
im gunna get them switched out for the dual 4's....
just threw in a yellow top today and took out the stocker, and on saturday im gunna go pay $150 (install) + $80 (knukonceptz 1/0g) for the big 3
anyone else think im getting raped by paying 150 for installing wires?
Old May 6, 2009 | 10:17 PM
EmperorJJ1's Avatar
ya 150 seems sorta high but its running wires thruout the car.
Old May 6, 2009 | 11:13 PM
brickloaf's Avatar
anything audio express does generally costs like 50% more than what others charge
bestbuy wont **** with alternators tho, and audio express is my only other option
Old May 6, 2009 | 11:20 PM
EmperorJJ1's Avatar
ya sux. wish i knew a shop close i could refer you too
Old May 9, 2009 | 07:23 AM
crumba's Avatar
i would worry more about your alternator. that's a big amp. and don't worry about the fan if its the power series. there made in America not Mexico. i have one pushing 2 t1 12s its fine. oh and take your trunk off because with that amount of bass no amount of dynomat is going to help the cobalt. and those amps are only stable to 1 ohm
Old May 11, 2009 | 12:27 AM
EmperorJJ1's Avatar
only thing i really disagree on is the dynamat part. I've used a ton of second skin and my trunk lid is solid. only rattles are from underneath the rear bumper somewhere. and in comparison its really nothing
Old May 11, 2009 | 12:58 AM
brickloaf's Avatar
yea i got the damplifer pro, get it from ups tomorrow, alreayd ripped all the **** out of my trunk so i can get all that **** installed tomorrow, and im hoping it works cuz these l7s would rattle my trunk off
Old May 11, 2009 | 01:04 AM
EmperorJJ1's Avatar
sweet did you get the roller too?
Old May 11, 2009 | 01:07 AM
brickloaf's Avatar
yea i thought that was prob a good idea, but i didnt get the cutter thing cuz i have like 5 of those at the crib
im hoping i have enough left over from the trunk to do the rear deck, i completly forgot about that when i ordered the trunk kit but my deck rattles like hell
Old May 11, 2009 | 01:13 AM
EmperorJJ1's Avatar
just space it out... ull be fine. oh ya the furry knife is bullshit anyway. looks cool but i broke mine
Meadowvalien
Aug 17, 2017 06:32 PM
ashalle2
Sep 17, 2015 04:58 PM
EmperorJJ1
May 19, 2007 04:59 AM
xspyder85x
Nov 25, 2006 07:24 AM
Screamin!
Aug 20, 2006 01:50 PM
