thought about something crazy...
Old Jun 6, 2010 | 08:29 PM
SS_T-Roy's Avatar
so i thought it would be interesting to try to put a tv in the trunk.
just a passing thought while i was cleaning the interior so i took some pics.
anyone ever done anything like this? i'm still thinking of what i could do or if this is even possible
Old Jun 6, 2010 | 08:31 PM
ssyellowss's Avatar
it could be done, but you'd need to fabricate some brackets to hold it. also you'll need a power source if its 120 volt.
Old Jun 6, 2010 | 09:02 PM
SS_T-Roy's Avatar
and the converter is out of question already. if i have the converter on it messes up the screen on the radio
the base of the tv actually can be took off so all i need to figure out is a bracket and where to mount
Old Jun 7, 2010 | 10:46 AM
warrenb213's Avatar
yes a tv in the trunk helps....especially out at camping parties.
you should mount yours on the inside of the trunk lid. that way u can still have stuff in the trunk. make it removable just in case.
i'm thinkin about mounting mine in for summer again
Old Jun 9, 2010 | 11:13 AM
insylem's Avatar
Cool, but so what if the Converter interfears with your radio display? Youll be in the back watching TV and not messing with the radio. Or are you wireing the audo for the TV through the radio?
Old Jun 10, 2010 | 11:49 PM
SS_T-Roy's Avatar
how would you mount it on the lid?
i think that will have to run it through the radio anyway, i just hope a converter won't mess up the tv in the trunk as well
Old Jun 11, 2010 | 12:07 AM
Blown07SS's Avatar
Anything is possible I've seen tv screens in the headlights years ago.
Old Jun 11, 2010 | 12:49 AM
warrenb213's Avatar
i'd build a mount out of aluminum and use a nut/bolt approach into the sub-structure of the trunk lid. from there explore the options available to you in figuring out how to attach your specific monitor to the mount, choose one, and go. in my case i'd probably be using a monitor which has the standardized mounting technique available, such as VESA. attach that monitor mount to the aluminum mount you made for the trunk, and blam you got a solid mount. the reason you'd want to use a sheet of aluminum is for strength so the monitor won't stress the stock substructure as much.
Old Jun 11, 2010 | 12:54 AM
rossshady120's Avatar
tv's go in the dash where there a distraction and illegal and i dont think the tv would like two 12's
DarrenGC
Dec 24, 2021 01:55 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
