Upgrade
Old Jul 5, 2006 | 03:01 PM
quickspec's Avatar
Question Upgrade
What subs will fit in the stock sub box and sound good in it.
Old Jul 5, 2006 | 03:07 PM
1stbluSS's Avatar
Solobaric l5
JL Audio W6
15 soft dome tweeters
Old Jul 5, 2006 | 04:24 PM
mesatrin's Avatar
Something that is made for a truck box. The dim and mounting depth of the factory box really isn't that big. Also you will probably want to look at a new amp if you are changing out the factor sub. I don't think it has normal sub connections.
I don't personally have the pioneer speaker package so I am not positive about the connections. I do however know the box is tiny from seeing it and from what other people have said about it.
And neither of the subs that 1stbluSS will fit into this box
Old Jul 6, 2006 | 10:42 PM
Blacksun's Avatar
Has anyone actually replace their factory sub with an aftermarket one. If so did it sound that much better???
Old Jul 7, 2006 | 11:13 AM
xtremeGM's Avatar
I replaced my factory sub, I used a infinity REF1052W. Sounds Excellent. But, you definantly have to add an aftermarket amp or its not going to sound good. Sometimes using aftermarket components and still using the stock amp make the speakers sound even worse than stock. I already had a new kenwood amp so I just used that amp.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
