Upgrades
Old Nov 27, 2009 | 02:03 PM
Zach19Dude's Avatar
Canada Upgrades
I have a 08 Cobalt Sport with the full Pioneer system but i wanted to hook up other subs to it and i doubt the stock amp with hold up. I got a 1000 watt amp and am looking to hook that up but wanted to keep the stock head unit. Wondering how about to go about it ? Any help would be greatly appreciated
Old Nov 27, 2009 | 02:05 PM
chitala383's Avatar
u need to splice in a line out converter to either the rear speakers or the stock sub, i used spliced mine into the stock sub wires and it works fine.
Old Nov 27, 2009 | 02:07 PM
Zach19Dude's Avatar
would that just be like that RCAs that im splicing into or what? im kinda new to the whole audio thing
Old Nov 28, 2009 | 12:21 AM
EmperorJJ1's Avatar
LOC turns speaker wire into RCA outputs for the amp. Splice stock sub and disconnect it
Old Nov 28, 2009 | 12:36 AM
krishansheanh's Avatar
look in the how-to section, theres a couple showing you how to do this
Old Nov 28, 2009 | 07:02 AM
Zach19Dude's Avatar
would that keep the stock amp working or no cause we were thinking about taking it out and just using the 1000 watt amp
Old Nov 28, 2009 | 11:49 AM
Sp33dyG's Avatar
stock amp -> LOC -> 1000watt amp -> subs
Old Nov 28, 2009 | 03:22 PM
warrenb213's Avatar
probably better for the long run to go:
stock reciever -> split them before the stock amp ->AudioControl Matrix(w/line driver and summing) -> Amp(s) -> Subs
This route would allow the user to avoid distortion and noise that comes with most LOC's(though typically unnoticeable), and allow the user to upgrade the stereo in steps.
it's a unit i'm considering buying here soon as well.
Old Nov 29, 2009 | 02:13 PM
Zach19Dude's Avatar
does the stock HU use RCA cables to go to the stock amp and if so could i just run a different set to the back to the new amp
Old Nov 29, 2009 | 11:29 PM
warrenb213's Avatar
the stock unit is sending low level rca signal to the stock amp, yes. just gotta do the splicing. there are cables out there meant for this.
Old Nov 30, 2009 | 12:23 AM
EmperorJJ1's Avatar
you would need to splice the loc after the amp. or just splice rca inline
Old Nov 30, 2009 | 06:28 AM
Zach19Dude's Avatar
so this is all im looking for ??
http://www.crutchfield.ca/ProductDet...4&Show=ExtInfo
Old Nov 30, 2009 | 06:35 AM
Beck's Avatar
yes.
Old Nov 30, 2009 | 08:18 PM
Zach19Dude's Avatar
okay so i got a stinger LOC and im just wondering what colours im going to be splicing into. i want to go off the original sub connector instead of the speakers? anyone know which ones i will be using ? ( i know there is four i just dont know what colours they are)
Old Nov 30, 2009 | 08:40 PM
Beck's Avatar
check around the How-to section, there's a write up for splicing into your rear speakers but i think it also tells you which one for the subs somewhere in all the pages.
Old Nov 30, 2009 | 09:12 PM
Zach19Dude's Avatar
i cant for the life of me find the link for the one with the sub wires. help anyone ? just looking for the colours to splice into
Old Dec 1, 2009 | 04:46 AM
EmperorJJ1's Avatar
there right there in the back on top of the sub box
Old Dec 1, 2009 | 06:41 AM
Zach19Dude's Avatar
i know where the wires are i just dont have the car here so i cant look and im wondering what color im gonna be splicing into if anyone knows
Old Dec 2, 2009 | 03:42 AM
EmperorJJ1's Avatar
sry i dont know the wire colors off the top of my head...
Old Dec 2, 2009 | 06:37 AM
Zach19Dude's Avatar
okay so we got it in with the LOC but it seems like we have to crank the amp right up in order to get any amount of bass. is there such a thing as like a preamp or anything that would boost the signal
Old Dec 2, 2009 | 10:16 AM
EmperorJJ1's Avatar
did you tap before or after the amp? if after pull out on of the rcas and see if it gets louder. if so u have one set of wires backwards.
Old Dec 2, 2009 | 02:26 PM
Stephenishere's Avatar
I posted this on another guy installing subs in his car, these guides helped me a lot through the whole install process. Takes all the guess work and prevents messups that are often a pain in the ass to fix/redo.
****MOST IMPORTANT ADVICE**** Make sure you unplug you positive terminal from the battery when working with any kind of electronics like this. I've been a ******* and got lazy in the past when installing a friends system in his car.(he was in a big hurry so I kinda did a rushed job) Anyways, after everything was hooked up and the fuse block was ready to have a fuse in it, I bumped a metal piece of the housing against the amp and poof. Nice big old smoke cloud came out of the amp.... I ended up replacing his amp with one of my old ones, luckily the amp I fried was a real cheapo so the one I gave him ended up working better anyways. Anyways here's my post, and good luck on the install.
When I installed my sub/amp, I used these two guides on how to install/ remove the seats and everything else. Very good write ups with great instructions on what to do.
How-to sub install
https://www.cobaltss.net/forums/show...ight=subwoofer
How-to upgrade stock sub with original housing
Another great guide, but for replacing the sub in the same housing, very similar to the first guide.
How-to weight reductions(great on how to remove parts in the way)
Good luck!
EDIT: I forgot to add, I wouldn't recommend wiring in a lineout converter to the stock subwoofer line. I tried it in my old cobalt and it caused all sorts of problems, had two converters just plain not work. I think the signal is too strong for most converters, although I eventually was able to get it to work with a PAC lineout converter(one I recommend for LOC's). Splicing the rear speakers isn't too hard to do, just takes a little while. Make sure you either use some real sticky electrical tap so no wires touch and possible fry something. I prefer using a little electrical tape around the two wires connection, and finish it off with shrink wrap around it. Makes a really nice connection and looks very clean. Heres a photo of one of my speakers splicing.
Old Dec 2, 2009 | 03:31 PM
Zach19Dude's Avatar
i did go after the amp right of the sub wires. i used this wiring diagram and went positive to positive and negative to negative on both but i will double check them when i get a chance
http://chevroletforum.com/forum/showthread.php?t=23406
and when you say pull out on do you mean completely out or just wiggle it around cause i know i was trying to get my brother to turn the stereo down and i pulled an RCA completely out and it pounded like crazy. almost scared me
Old Dec 3, 2009 | 12:23 AM
brickloaf's Avatar
Are u talking about rcas on the loc or amp? I always figured you couldn't put rcas "backwards" on amps if u know what I mean
And to the guy above me yea when u pull out your rcas with the amp on it thumps for like a split second
Old Dec 3, 2009 | 01:02 AM
EmperorJJ1's Avatar
pull out completely. If you did that and it pounded like crazy then you have one of the wires backward... out of phase. meaning one channel is getting pos into pos neg into neg, the other is getting pos into neg and neg into pos. So the signal is basically canceling out before. hence why the single rca is louder then both. and when wired correctly both will be twice as loud (also your going to need to readjust just the amp before u break something)
brick is talking about a pop out of the rca when u pull it. If its playing quietly you yank an rca it pos then back to quiet then it isnt an issue with the rcas being out of phase.... but if you yank one rca and it get louder and stays that way then thats the problem
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
