Upgrading Pioneer Audio system
Old Nov 10, 2008 | 04:09 AM
Boz1285's Avatar
Question Upgrading Pioneer Audio system
I'm looking to upgrade my whole system in my 09 ss. I've already put in the kenwood ddx512 and for the rear sub i want to just get a shallow mount sub and mod the stock box. As for everything else i have no clue whats good. I cant seem to find anywhere that gives the specs on all the stock speakers/tweeters. What would give me a good sound upgrade?
Old Nov 10, 2008 | 04:48 AM
OneCOLDBIZL272's Avatar
6in the the front door and i think the tweeters ar like 1.5" and the rears are 6x9"
And Pioneer AVIV-D3 indash dvd/navy for radio
and i would go with sony,mtx,rockford phasgates,or kenwoods for the speakers my
Old Nov 10, 2008 | 01:14 PM
Boz1285's Avatar
i've already got the head unit and i know the sizes. i'm talking about finding something that would be tter than stock as far as sound and power
Old Nov 10, 2008 | 05:52 PM
two 12s with a 1000 watt amp
Old Nov 10, 2008 | 05:58 PM
Jplaya023's Avatar
yea two twelves, not even 1000 watts, 500 would be nice as well...JL Audio is an extremely good company...it costs a little bit extra but its definitely worth the money. Ive had my subs for over 6 years and they still sound like the day i got them...as for the 6.5s....i went with pioneer and got a 4 channel amp...they sound amazing and make a huge difference. one recommendation would be to stuff your box with polyester stuffing to soften that hard "wood" sound you get from the bass bouncing off the MDF. also, if you're looking for really crisp sound...have the entire trunk dynomatted. Stereo equipment gets expensive but if you want it to sound nice, you have to do it right.
Old Nov 10, 2008 | 06:05 PM
HatedCobalt's Avatar
i took pinks stock sup out which is a duel voice coil sub. when i did i found that the stock amp is a 2 channel cause there was 2 positive and 2 negative on the stock harness one set running to each coil. so i hooked up two 10" memphis pr subs to the stock amp and it works super. much more bass. very simple to do and a worth while upgrade.
Old Nov 10, 2008 | 06:47 PM
Jplaya023's Avatar
where is the stock amp located?
Old Nov 10, 2008 | 07:28 PM
some where in the trunk or back seat area i think
Old Nov 10, 2008 | 07:44 PM
has nothing to do with the factory amp. unbolt ur stock sub and on the top is a plug. unplug that and remove the stock sub. not take the sub out of the box and cut the wires off the back of the sub. then pull the plug on the outside of the sub box and remove the plug and wires. then plug it back into the car and wire ur new subs. the wires you pulled out of the stock sub box are black and red so hook up is easy. and questions feel free to pm me.
Old Nov 10, 2008 | 08:22 PM
wait maybe im retarded ...but im confussed, i do what it i want to remove me stock sub and put 2 12 subs in a box in?
Old Nov 11, 2008 | 04:50 AM
EmperorJJ1's Avatar
anything other then pioneer or kenwood would sound better then stock. look around and see what you can listen to.
no he wants you to put more power on the stock sub... can be done but might as well put something aftermarket
Last edited by EmperorJJ1; Nov 11, 2008 at 04:50 AM. Reason: Automerged Doublepost
Old Nov 11, 2008 | 02:43 PM
Boz1285's Avatar
I was thinking about the Alpine type rs or infinity, i've head good things about both.
Old Nov 12, 2008 | 11:32 PM
EmperorJJ1's Avatar
ya those a pretty good door speakers
Old Nov 13, 2008 | 04:29 AM
Boz1285's Avatar
what about for the rear deck?
Old Nov 13, 2008 | 05:33 AM
sptrdss's Avatar
i put infinity kappa's in my rear deck on my 09 ,great speakers!
Old Nov 13, 2008 | 10:21 PM
EmperorJJ1's Avatar
same i just used the term door speakers to specify the midranges
Old Nov 14, 2008 | 02:52 AM
Boz1285's Avatar
ah, right on
Old Nov 28, 2008 | 10:26 PM
hilty003's Avatar
so our door speakers are 6"? i was looking on bestbuy.com just to get some ideas and they label theres like 6-1/2" is that right? im looking for door speakers with a nice looking cover so you can tell their aftermarket. ive never messed with speakers before and found this thread so i thought id just ask instead of starting a new one.
Old Nov 28, 2008 | 10:33 PM
EmperorJJ1's Avatar
the door speakers are 6 1/2 dont get 6's they will barely fit/ not fit if you know what i mean
Old Nov 29, 2008 | 12:07 AM
hilty003's Avatar
http://www.bestbuy.com/site/olspage....=1166234894507
^im looking at something like that with a nice cover. im kinda thinking about getting a pioneer set tho so i can keep the system all the same brand.
im really liking these:
http://www.bestbuy.com/site/olspage....=1197678618335
they gotta be better than the stock pioneers
Old Nov 29, 2008 | 12:14 AM
EmperorJJ1's Avatar
esh i would go with infinity over pioneer anyday
Old Dec 9, 2008 | 09:28 PM
kovich14's Avatar
I am told the stock 10" sub is more shallow than other 10" subs, thus you cant use any old sub...is this true?
Old Dec 9, 2008 | 09:31 PM
joeworkstoohard's Avatar
agreed.
i bought the kappa 6.5" set and they sound really nice. esp with a little power going to them.
i had to make an adapter out of some ABS plastic, but it worked.
Old Dec 10, 2008 | 03:18 AM
EmperorJJ1's Avatar
yes your going to need a shallow sub.
Old Dec 10, 2008 | 11:44 AM
kovich14's Avatar
Now, let me just make sure that i understand. I am going to use the stock enclosure with a shallow sub. I should be able to use the speaker wire that runs out to the stock sub to input signal to the high-level jacks on my amp, correct? This seems like the cleanest way to use an aftermarket sub in the stock enclosure. Any suggestions?
