Urgent Help Needed
Old Feb 2, 2009 | 09:52 PM
bruiserinpink's Avatar
if i bought the cheper harness, my cars an 06, could i still listen to the radio with the car off if i buy the cheap harness??
Old Feb 2, 2009 | 09:59 PM
EmperorJJ1's Avatar
if you wire the accessory to the sunroof fuse then you can listen to the radio in both the acc and on position along with the key in. you also should retain the rap feature that keeps it on 10 mins after turning off the car
Old Feb 2, 2009 | 10:08 PM
dman090's Avatar
listen to this guy he is car audio king lol
and BTW i sent you an email with the pinout pink
Old Feb 2, 2009 | 10:41 PM
i don't have a sunroof, i have an LS, yeah i know he knows his ****, i been PM'ing him for help outside of this
Old Feb 3, 2009 | 01:38 AM
EmperorJJ1's Avatar
doesnt matter
Old Feb 4, 2009 | 05:29 PM
ohhh so theres a fuse for it even though i don't have a sunroof?
Old Feb 4, 2009 | 08:00 PM
Spun's Avatar
yes thats right
Old Feb 7, 2009 | 05:06 PM
okay so, we bought a new harness and we have everything hooked up BUT it's STILL NOT WORKINGG!!!
heres some pictures...
Last edited by bruiserinpink; Feb 7, 2009 at 05:06 PM. Reason: Automerged Doublepost
Old Feb 7, 2009 | 08:17 PM
EmperorJJ1's Avatar
why aren't you using the ground in the harness? and where do you have that ground going to?
show me a close up of the harness... like facing the pins
Old Feb 7, 2009 | 10:40 PM
okay guys we got it to work...FINALLY EVERYTHING WORKS!! thanks for everyones help!
okay scratch that.. which fuse do i use? and with the fuse tap, do i put the fuse in with the fuse tap?
Last edited by bruiserinpink; Feb 7, 2009 at 10:40 PM. Reason: Automerged Doublepost
Old Feb 8, 2009 | 02:05 AM
  #36
EmperorJJ1's Avatar
yes... sunroof fuse
Old Feb 8, 2009 | 12:28 PM
  #37
theres no fuse in there though and when we did try it when we bought the fuse it wouldn't work to begin with.. like ti won't even stay in place because theres no metal in there to hold it into place. also the screen is now saying "caution: screen image may appear reversed" and idk what that's about either..
Old Feb 8, 2009 | 12:29 PM
  #38
dman090's Avatar
waht size fuse u using for it?
Old Feb 8, 2009 | 12:31 PM
  #39
we tried the only one that would work was number 8, the 2 amp fuse ignition switch
Old Feb 8, 2009 | 12:33 PM
  #40
dman090's Avatar
the sunroof fuse didnt work? all i did was take the one out that was in there and put the fuse tap in?
also waht did u use for the dvd bypass?
Old Feb 8, 2009 | 12:35 PM
  #41
does anyone know why it's saying the screen image may be reversed because it won't let us do anything while it says that..
there wasn't a fuse in the sunroof fuse, and i don't think theres anything even back there because it won't hold the fuse tap in.
We ended up using a switch for the bypass
Last edited by bruiserinpink; Feb 8, 2009 at 12:39 PM. Reason: Automerged Doublepost
Old Feb 8, 2009 | 12:51 PM
  #42
Tazmanian_Dvl's Avatar
Originally Posted by bruiserinpink
well ****.. they sold me the wrong one so i pertty much just threw away 50 bucks because i went to a shop that doesn't have exchanges or returns no exceptions!! dangit!! and i also paid someone to finish the job who ended up ruining it more, which was another 50 so i pretty much wasted 100 bucks!!
Did you pay for it with your debit card or credit card? If you did call your credit card company or go to the bank and do a charge back. Tell them "the item didn't work as they advertised and they wouldn't return it or exchange it"
Old Feb 8, 2009 | 01:17 PM
  #43
EmperorJJ1's Avatar
huh what about the wiper fuse
reset the unit... make sure the reverse wire isnt getting power. Thats either a setting in the unit or the reverse wire getting voltage. there should be a small reset button in the front
Old Feb 8, 2009 | 02:19 PM
  #44
tried the wiper fuse, no go.. any more ideas? what about like me running it to the engine bay? is there anything there i can hook it up to?
Old Feb 8, 2009 | 02:22 PM
  #45
EmperorJJ1's Avatar
not really. you can tap the main acc wire for the car but you wouldnt retain the rap feature.
Old Jan 21, 2010 | 11:13 PM
  #46
emp, hey.. so were trying the sunroof fuse and there is nothing going to it, it's just 2 holes.
Old Jan 21, 2010 | 11:51 PM
  #47
EmperorJJ1's Avatar
damn u might be screwed then if the wiper fuse doens't work and the sunroof isnt there (which is uncommon but a few have had it happen) and u want to keep the "rap" feature. You can try locating the RAP wire in the kick panels but i dont know if u will have that either
Old Jan 22, 2010 | 12:21 AM
  #48
ya the wiper fuse will come on with the car now but it won't keep all my settings. all i care about is it coming on when i turn the car on and keeping all my settings each time, instead of going through the demo and having to manually go through the channels each time!
Old Jan 22, 2010 | 04:34 AM
  #49
EmperorJJ1's Avatar
double check the acutal power ur getting if ur settings are being reset. either the fuse or connection somewhere on the acc is loose and messing it up or something bad with the constant
Old Jan 22, 2010 | 05:26 PM
  #50
could it be that there's a problem with the sunroof fuse itself? since everyone says thats where it should go since i don't have one but it's not working there...
