What could be the problem?
Hi, I recently bought a 2006 cobalt ls, and I LOVE IT! I recently had the clutch replaced and now I have another problem. This only happens once in a while... maybe once/twice a week but is becoming more often... sometimes when I turn the key, all of the electronics come on... dash lights, radio, cigarette lighters, etc... but it doesn't turn over. As a matter of fact, it doesn't make any noise. I can hear the fuel pump but that's it. No clicking ticking or anything. It's not the starter because it starts 70% of the time. I'm getting frustrated bc I can't count on my car to start half the time. What could be the problem??
Well what do u have to do to get it started after it does that
Originally Posted by tomj77
(Post 7628320)
It could be a number of things, start with getting the battery and alternator tested. If those check out good, then check the bolts in the fuse box and make sure they're tight (30-40ft/lbs). After that it's grounds and starter. |
Originally Posted by ECaulk
(Post 7628375)
I'm going to assume they roll start it.
(Post 7628320)
Pop the cover off the underhood fuses, you'll see the bolt heads I'm talking about. I forget how many there are.
(Post 7628405)
