What went wrong?
Old Apr 3, 2010 | 02:03 AM
curtis0432's Avatar
What went wrong?
Hey guys I just installed my alpine CDA 105 in my car. All seemed to go right until I decided to take it for a test drive. On the test drive the I noticed that my head unit will turn on and off just cut in and out. So basically I turn my signal lite on and the head unit shuts off. and about 20-30 seconds later after the signal lite is off the head unit turns back on. What is the problem here I am totally stumped.
I used the PAC module interface and harness to install if that makes any difference. Everything worked good until I started driving it.
Old Apr 3, 2010 | 03:20 AM
Spun's Avatar
What year and trim is your car?
What is the model # of the harness and interface you used?
Old Apr 3, 2010 | 03:26 AM
curtis0432's Avatar
well its a 2005 Pontiac Pursuit 4 door sedan. with no on-star or no pioneer sound system. Its just the base model. The Pontiac Pursuit is basically a re badged cobalt. instead of Chevrolet badges its Pontiac. they look the same and they are basically the same. and the Module/interface that I used is PAC C2R-GM11b.
Old Apr 4, 2010 | 02:06 PM
EmperorJJ1's Avatar
sounds like the interface is busted
Old Apr 5, 2010 | 07:32 PM
sanchez's Avatar
i had this problem with my 07 ss and it was the pac black box that was doing it install went all fine till i left the parking lot and turned my turn signal on and the headunit would shut off like yours is so i took it back and they swapped the pac box out for another one and it worked fine after that
Old Apr 5, 2010 | 07:41 PM
koch1ar's Avatar
my installer tapped mine into something that auto dims and would only work with my lights on
Old Apr 5, 2010 | 11:06 PM
EmperorJJ1's Avatar
^^^ that sounds shitty
Old Apr 9, 2010 | 12:16 AM
brickloaf's Avatar
Yea they always find some way to **** up something simple
Old Apr 9, 2010 | 01:12 AM
EmperorJJ1's Avatar
LOL... damny brick made my night with that comment
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
toledobalt
Sep 2, 2015 07:04 AM
