What's that pioneer headunit...?
Old Sep 2, 2012 | 01:26 PM
06SS ALL DAY's Avatar
The DVD touch screen that says SS when you start your car up?
Old Sep 2, 2012 | 01:31 PM
08G5GT2.4L's Avatar
there isnt one. you can make your own custom bootscreens tho to have the ss logo.
Old Sep 2, 2012 | 02:11 PM
Good call lol. Does anyone know which ones do that and the procedure?
Old Sep 2, 2012 | 05:07 PM
Will this fit? Pioneer AVH-P4300dvd
Old Sep 2, 2012 | 05:47 PM
jp1600's Avatar
Yep, got one
Old Sep 2, 2012 | 11:04 PM
Cool. I just picked one up off this shady dood on Craigslist hahahaa. It works tho. Just gotta find a place that sells that mountin hardware. Fmllll. I went to the 24/7 Walmart and they def didn't have it. I highly doubt anyone will stock it. Where'd you get yours from?
Old Sep 2, 2012 | 11:25 PM
DarkChild's Avatar
Go to a local audio store. Not Walmart, Bestbuy, or a Futureshop, etc.
Old Sep 3, 2012 | 03:46 AM
EmperorJJ1's Avatar
right although if your BBY has an install bay they should have it. Thats where i have my most current mounting bracket
Old Sep 3, 2012 | 02:43 PM
Ok I bought the metra double din kit 99-3302 or whatever. Now I need a toggle switch for the DVD player trick lol. If anyone has any tips or tricks for the install of a pioneer avh-4300 lmk. I did look at the how to's The first one the guy said it took 12 hours. Right off the bat I knew not to follow his directions for a few reasons as follows. Im not retaining the wheel controls, I don't have the problem with door chimes (thank god), and ultimately it should take an hour tops of your taking your time. All I want to know will or do I have to bend metal or cut anything such as tabs etccc to make a perfect fit. I already have a power source with a fuse installed for my previous pioneer h/u. It was a single din unit. Will I have to change the fuse for a bigger one? Sorry if this is all sounding confusing. I confuse myself sometimes. No joke lol
Old Sep 3, 2012 | 04:49 PM
EmperorJJ1's Avatar
fuse should be ok. plastic probably has to be cut and metal bar might or might not need to be unbloted/removed
Old Sep 3, 2012 | 06:25 PM
Ok this mute wire. I don't need to use it correct? I don't have Bluetooth or anything. (someone told me its for Bluetooth setup.
Old Sep 3, 2012 | 09:21 PM
Everything is working perfectly. Tomorrow I'll hook up the switch for the DVD player. Can't put jpegs on my iPhone so now I gotta figure out another way to change the background to an imagine I want. Grrrr
Old Sep 3, 2012 | 09:55 PM
DarkChild's Avatar
The switch is just ground out. Extremely easy to do. Get a momentary switch that is always closed, you can get the ones that are always open and you don't want those.
Green wire goes on one peg, and you ground the other peg out to the closest ground. Easy as that.
Old Sep 4, 2012 | 01:42 AM
EmperorJJ1's Avatar
right.
oh and to answer another question without quoting: im pretty sure you have to upload the background from a USB flash drive regardless
Old Sep 4, 2012 | 11:40 PM
tomj77's Avatar
i got the avic 140bh, just put a pic on a memory card, put it in, go into settings on the deck and install it. very easy
Jan 12, 2016 12:01 AM
chefhhr
Oct 26, 2015 10:36 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
