who has 2 12's in the trunk?
ok i have 2 12" kicker comps, i need a box that can be easily removed from the trunk for when i race... anyone have dimensions for a box?
Also im not sure how good it is to run them in a smaller box then is needed.
any suggestions?
BTW i will be running 300rms to each...
any suggestions?
any suggestions?
any suggestions?
ok so i need 1.25 cuft per driver and that includes driver displacement. It will be a sealed uint, so im thinking h14" w17" L31" after the 3/4' mdf that should be 2.4953 cu ft
sound right?
sound right?
yup. you can go ahead and put them in a smaller box if its more convenient for you but a smaller box wont be as loud. you can probably drop it down to 1cu per sub and be fine thou if you wanted. also try making it so you can pull the box out of the trunk opening and it will be easier to remove
camaromanss1992
Oct 1, 2015 10:51 PM
royce777
Sep 28, 2015 07:11 AM
