wideband? and fusebox help please
Old Jun 5, 2008 | 07:34 PM
24SSNighthawk's Avatar
so widebands can track a\f right? how would one install a gauge or pick a gauge? and the second question i had was how would i tap the fusebox for a constant power source? looking for help with interior lights (pretty new to this) any help?
Old Jun 5, 2008 | 09:07 PM
lil_kano's Avatar
might want to run it on an ignition line so it doesn't drain your battery.
as far as connectiona and power source i can't help you but some one will chime in. bump
Old Jun 5, 2008 | 09:09 PM
SSMOKEM's Avatar
The radio or int. lights
Old Jun 6, 2008 | 09:05 PM
radio would work, int lights arent constant?
Old Jun 9, 2008 | 02:49 AM
bump. alright can anyone help me with the fusebox, is there any possible way to set another fuse for just leds or neons themselves instead of pulling it from an existing source? and if so how many watts amps? will it be 12v?
Old Jun 9, 2008 | 02:51 AM
ColeJJones's Avatar
Bannned
dude. go take a picture of your fuse box and i will show you which one to tap into
or find me a picture
ugh its 240... i just hit a deer on the way home from my girlfriends... coincidently we just broke up 1 hour ago...?
Old Jun 9, 2008 | 02:57 AM
ColeJJones's Avatar
Bannned
wtf?
just for you
Old Jun 9, 2008 | 03:03 AM
ohh poo, you wouldnt happen to know of an interior picture ? well can i just tap any available fuse? or hows it rated?
Old Jun 9, 2008 | 03:05 AM
ColeJJones's Avatar
Bannned
yea, the one you can tap in your car is a 10. its the upper part on the right side. that fuse turns off with your car
Old Jun 9, 2008 | 03:08 AM
OneSlowGto's Avatar
I ran a wideband and a aeroforce to the sunroof fuse on the passenger side fusebox in the cabin. It worked well and I never had a problem.
Old Jun 9, 2008 | 09:19 PM
i want to tap any fuse, my question is are all EMPTY fuse slots constant power sources? and can i tap them with a 15 amp fuse? how do i tell which way the power goes? im about to start tonight if i can get any help. ohh yeah if i tap an existing fuse whats the best way to go about it, wrap the wire around the prong? is there a better way?
Old Jun 9, 2008 | 09:33 PM
chad463's Avatar
I am pretty sure I tapped into fuse 22 in the car for my wideband. It is an extra slot so there is nothing else connected in there. I would just by an add a circuit kit and make it clean.
Old Jun 10, 2008 | 12:03 AM
well i think i totally fucked it then, i ran it to the int lights, and i just wired it straight in hope thats not tooo bad, i couldnt find a fuse tap when i was at advanced auto parts today, need electric tape now, maybe walmart can help...
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
xxenjoi11
Sep 29, 2015 12:36 PM
n20saturn
Sep 21, 2015 01:50 AM
Gugi96
Sep 15, 2015 12:24 AM
