Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   Featured Car Showcase (https://www.cobaltss.net/forums/featured-car-showcase-74/)
-   -   KMO43 FCOTM + Build Thread (https://www.cobaltss.net/forums/featured-car-showcase-74/kmo43-fcotm-build-thread-319300/)
KMO43 Sep 26, 2015 01:05 PM
19 Attachment(s)
Attachment 13760
Car: 2010 Cobalt SS/TC Summit White
Stock Options: XM, Onstar, RPD, Sunroof, Pioneer Sound System
Performance:
-7163 ZFR
-Hahn CAI
-Hahn Catless DP
-Hahn Cat Back Exhaust
-Hahn Charge Pipes
-ZZP Intercooler
-Ported Head, Intake Manifold, Exhaust Manifold & O2 Housing
-Supertech Valesprings Ti Retainers
-ARP Headstuds
-Snow Stg2 Meth Kit 500cc Nozzle
-Southbend Stg4 Plate & Stock Disc
-ZZP Transmission Mounts
-ZZP Engine Mount
-Forge BPV
-Turbosmart Dual Port 23psi Actuator
-LSJ 4.05 Trans
-HP Tuned @ 29ish psi
-Mishimoto Rad
Wheels, Suspension, Brakes:
-Stock TC Wheels Powder Coated Semi Gloss Black
-Nitto NT01s 235/35ZR18
-Eibach Sportline Springs
-ZZP Stainless Steel Brake Hoses
-ZZP Cross Drilled & Slotted Rotors
-Hawk HPS Pads
Interior:
-ZZP RPD Dual Gauge Pod
-AEM Meth Flow Gauge
-AEM Boost Gauge
Future Plans:
-More Fast
A special thanks goes out to: Jon (SylverSS/SC), Nathan112i, Taylor (Infraredline):usa:, Jonathan (Soundjunky), Mark (Jrmotosports 88), Sammi from Mr. Detail & Matt from Turbobay
Attachment 13761
Attachment 13762
Attachment 13763
Attachment 13764
Attachment 13765
Attachment 13766
Attachment 13767
Attachment 13768
Attachment 13769
Attachment 13770
Attachment 13771
Attachment 13772
I have both set on red but can choose tons of colors
Attachment 13773
The beauty
Attachment 13774
Attachment 13775
Attachment 13776
Attachment 13777
Attachment 13778
KMO43 Sep 26, 2015 01:07 PM
I'm working on the build part right now I'll be posting it soon!
Slowbalt2000 Sep 26, 2015 02:11 PM
Nice pictures! Good to finally see your thread bro :twothumbs.
Car is clean af and i envy your build
KMO43 Sep 26, 2015 02:16 PM
20 Attachment(s)
STG1
I ordered the car sight unseen and didn’t even test drive it before. I asked for white as my first pick and was only told that I would be happy by my salesman.
The first time I ever saw my car
Attachment 13738
Attachment 13739
Attachment 13740
Car taken home
Attachment 13741
Attachment 13742
Attachment 13743
Attachment 13744
I was always planning on building the car origanally I was looking for around 300hp I dynoed stock at 220hp240tq on a mustang. So just aftermy first oil change I installed all my bolt ons CAI, DP, Exhaust, IC, IC Pipes and a terrible PPC tune
Attachment 13745
Attachment 13746
Attachment 13747
First trip with the car to Clagray where I live now
Attachment 13748
Attachment 13749
Attachment 13750
Because I had that terrible tuner I added meth to control the knock. Also during the first winter I added a southbend Stg4 clutch, Fidenza aluminum flyfheel, ZZP mounts, ZZP stainless brake hoses, HP+ pads and 6k HIDs
Wheels up!!
Attachment 13751
Attachment 13752
Attachment 13753
Attachment 13754
Attachment 13755
Attachment 13756
Attachment 13757
14 Attachment(s)
Stg2
Well I had my Hahn intercooler split on a weld and didn’t notice it right away so it blew up my turbo. I talked to Matt at Turbobay and got hooked up with one of the first K04rs.I had enough with the shit tune so jumped on the HPT team added the ZZP gauge pod switch to a ZZP intercooler with cast endtanks also lowered on Eibach springs
Attachment 13724
Attachment 13725
Attachment 13726
Attachment 13727
Attachment 13728
Attachment 13729
Attachment 13730
Attachment 13731
Attachment 13732
Here’s a log on the K04r spool
Attachment 13733
As I have terrible luck so driving a buddy home I bottomed out and took out my Intercooler and Rad. 2nd IC of the year
Attachment 13734
Attachment 13735
Jon (SylverSS/SC) hooked me up with a Mishimoto rad and I bought a local IC just to get me by
Attachment 13736
I’ve been told that I have an issue of not sleeping and just staying up late thinking of how to get more power from my setup and I was confused on how that 65mm wheel can’t hold boost up top. So one night I had an idea to test out a higher pressure actuator and wow it was the wake up call for that turbo!! I now was able to hold 28psi to my redline and have tested 30psi to 7k!! On pump and spraying meth I’ve seen 39lbs/min flow and I’m sure on e47 it’ll break 400hp
Attachment 13737
I’ve posted a ton in the K04r thread you can check it out here
https://www.cobaltss.net/forums/2-0l...o-swap-310943/
So I raced a 5.0
And a roll vs a buddy’s fully bolted K04 car
KMO43 Sep 26, 2015 02:18 PM
Thanks!! I try to keep it clean looking but she needs some love I've been super busy
SylverSS/SC Sep 26, 2015 02:23 PM
Look dad......wheels up!
KMO43 Sep 26, 2015 02:50 PM
Haha a Balt or 2 on stands is a pretty normal sight at my place
KMO43 Sep 26, 2015 03:17 PM
20 Attachment(s)
Stg3
I was really happy with how my car had been running on the bigwheel but I had been in love with the 7163 since I saw it was coming out and made the jump but I had a slight 5th gear set back again and Jon (SylverSS/SC) once again hooked me up with a LSJ LSD F35
Attachment 13704
Attachment 13705
Jonathan (Soundjunky) lent me his spare Intake manifold so I could make a mess of it! Plus some exhaust bit so I could get the coated after I ported them
Attachment 13706
Attachment 13707
Attachment 13708
Attachment 13709
Attachment 13710
Attachment 13711
Attachment 13712
Attachment 13713
Attachment 13714
I picked up a head from a guy and did a port job for some more flows!!
Attachment 13715
Attachment 13716
Attachment 13717
Attachment 13718
Here’s the ported head, stucs and supertech springs
Attachment 13719
Attachment 13720
Attachment 13721
I bought the turbo with the high boost actuator and it liked to run at 32psi so I switched to the medium and max was 29psi so I bought a Turbosmart dual port actuator now I’ve hit as high as 34psi and but currently am on 28psi. If you buy an EFR get one!
Attachment 13722
Love that boost curve!
Attachment 13723
Double post Fixed
KMO43 Sep 26, 2015 03:20 PM
Forgot to post but the 7163 thread I've shared a ton of info in there too
https://www.cobaltss.net/forums/zz-p...63-zfr-304838/
KMO43 Sep 26, 2015 03:22 PM
1 Attachment(s)
Stg4?
I’m parking my car here soon for the winter and will be doing a build again to go with the added boost and ported head but may also include.....
Attachment 13703
Thanks for looking and I hope you like my car!!
Snail_SS Sep 26, 2015 03:43 PM
That turbo is huge lol good luck bro
KMO43 Sep 26, 2015 03:49 PM
Thanks eddy!
Not if taylor desides to be an ass and throws on that 6466!
CobaltSS 16 Sep 26, 2015 04:34 PM
This is a sweet car.. I like it. good story too lol
that thing moves out.
KMO43 Sep 26, 2015 04:37 PM
Thanks!! I have a lot to do today so i hope i didnt miss anything
tomj77 Sep 26, 2015 05:51 PM
So sexy. Just unhahn those charge pipes and intake, unless they are the new aluminum ones
Snail_SS Sep 26, 2015 06:47 PM
Originally Posted by KMO43 (Post 7567305)
Thanks eddy!
Lol let's see what happens I wish I could see the race go down in person
BTW you posted the stg 3 pics 2 times
Devin86 Sep 26, 2015 07:35 PM
Awesome man!! Good luck!! Everthing is looking great!! This makes me want this turbo so much more!!
Snail_SS Sep 26, 2015 07:36 PM
I want that turbo as well maybe BF if not till next year
KMO43 Sep 26, 2015 08:22 PM
I'm thinking of custom making a 3+in intake with my buddy Kyle who did Jon's custom DP and getting it possible ceramic coated for heat control
Well come up to ND when it does down!!
I think this is the BEST turbo for our car good for DD around 400 and i guess we'll see what it can do next year
Snail_SS Sep 26, 2015 08:28 PM
Well I think any turbo would be fine it all comes down to the tuning lol
I wish I could lol
nathan112i Sep 26, 2015 10:41 PM
nice car bud, whats with the green coolant?
KMO43 Sep 26, 2015 10:56 PM
I'm cheap and have had 3 rads in my car so that's what I had
KMO43 Sep 26, 2015 11:02 PM
I wish I could lol
My choice would be K04r or 7163
I like tuning big turbos
